Um....desalting a new coil.....
- Location: My desk, somewhere in the east of somewhere....
So after ages of fear of winding my own coil....I finally did. I used salt.
Even double wound it!!!
So....how the bugger do I get salt out. I tapped and rotated it the best I could, and then plugged one end to my sink (with a barb fitting).....and after a few hours.....it ain't moving.
What will dissolve salt better than water? Can I leave it in water, so the water will penetrate the salt, without the issue of bubbles in confined tubes? (ie: air pressure of the air in a tube will not let water flow in the tube, so no water gets to the inner part of the tube)
I want my last words to be:
"Hey, this is kind of fun!!"
I'd throw it in a pan and simmer on the stove for a bit. You should get enough water in there to disolve the salt that way. If that doesn't work, means you have a kink in the line somewhere.
That's one of the reasons I made two seperate coils then used a pair of manifolds on the outside of my condensor.
You can see what I did here:
http://homedistiller.org/forum/viewtopi ... 5&start=21
Perhaps the higher water pressure from the hose will help. Good luck.
Cheers,
J
Cheers,
J
Re: Um....desalting a new coil.....
After a few MORE hours at more or less leak proof faucet connection, in a bucket of hot water....nuttin.
Might try pressurizing a pressurebucket to 150psi, and pulling a vacuum on the other end. Might use warm ethanol, or acetone to see if the salt dissolves faster.
kinnda pissing me off now.....
The salt should dissolve in boiling water... Your condenser can't be so large that it won't fit into a pot of boiling water...
when you hook it up to the water line is there even any slow drips coming out the other end??
if not id say you got a kink in there or something plugging it up. taste the water your using, if its salty, just give it more time.
Ok, just got done winding my coils. First time I've had to salt one. I haven't removed the salt yet as I'm being a little forcefull with some of the construction at this point.
What I have noticed is that as I adjust the diameter of the coils (twisting it open slightly) that loosens the salt. Probably have lost 1/2 out of each coil so far.
You might try holding each end and giving it a gentle twist, back and forth a few times.
Riff , if you haven't de-salted the coil by this time...Look at the thread Winding Coils!
Never refuse to do a kindness unless the act would work great injury to yourself, and never refuse to take a drink-- under any circumstances.
- Mark Twain's Notebook
