Thoughts on using this as a condensor?
I'm new to this and am building a Bok with a 2" column. I'm interested in using the heat exchanger (pictured) as a condensor. It's solid copper, has a 1/2" copper tube core, 1 1/2" OD with fins spaced approximately 1/8" apart. I have about 18" of it. I figure I could try it and if it doesn't work well I can always replace it with something more traditional. Opinions?
Re: Thoughts on using this as a condensor?
Are thinking, “air cooled”?
Or, are you going to put a water jacket around the copper fins?
Huge difference.
Former idea....
Latter idea....
Huge difference.
Former idea....
Latter idea....
I'll run water through the core and install it in the top of the Bok still. The fins will get cold and vapor will condense on them, drip down and make magic happen (hopefully).still_stirrin wrote:Are thinking, “air cooled”?
Huge difference.
Former idea....
Latter idea....
should work. looks cool either way
post your still pics here
http://homedistiller.org/forum/viewtopi ... 16&t=66917
- Twisted Brick
You may need to put it in a 45* jacket like Manu's. Gravity would assist drainage of those narrow fin gaps and at 18" I'd guess the 1/2" core would work nicely.
- raketemensch
I’d bet aiming a fan at it would work too. Pumps are for the unimaginative
Nice find!
It can be used 2 ways:
1) vapour inside, cooling outside or
2) cooling inside, vapour outside.
For cooling you can use water or air.
I don't know the math for this, but maybe you can try.
Could be a new type of condenser: RJP condenser.
Thanks, I'm concerned about draining the narrow fin gaps as well. I'll look into the Manu example. Maybe cutting each fin 4 times (90 degree increments) and giving the cut fin a little twist would help?Twisted Brick wrote:You may need to put it in a 45* jacket like Manu's. Gravity would assist drainage of those narrow fin gaps and at 18" I'd guess the 1/2" core would work nicely.
RJP condensor, I like that!Kareltje wrote:Nice find!
Thanks!nuntius01 wrote:should work. looks cool either way
The Manu design suggestion is a really good one, I think this condensor will work really good in that application. Thanks everyone, joining this group is already helping me!
- Twisted Brick
I think that's a great idea. Getting the fins even a little closer to vertical while the tube is at a 45* angle would help with returning reflux. But manually tweaking all those fins uniformly would have me pulling my hair out.RJP wrote: Thanks, I'm concerned about draining the narrow fin gaps as well. I'll look into the Manu example. Maybe cutting each fin 4 times (90 degree increments) and giving the cut fin a little twist would help?
I am not sure what you mean, but he could make a tool to do it uniformly. Maybe of wood: softer than copper.Twisted Brick wrote:I think that's a great idea. Getting the fins even a little closer to vertical while the tube is at a 45* angle would help with returning reflux. But manually tweaking all those fins uniformly would have me pulling my hair out.RJP wrote: Thanks, I'm concerned about draining the narrow fin gaps as well. I'll look into the Manu example. Maybe cutting each fin 4 times (90 degree increments) and giving the cut fin a little twist would help?
A cutoff wheel in an angle grinder should make cutting slots in the fins relatively easy. That style fintube usually has fairly stout fins. With slots, a fintube cold finger could make a slick condenser for the Dad300 condenser controlled still. Very interesting material. I am interested in how it works for you.
- Twisted Brick
Something like this:Kareltje wrote:[
The tool twists each fin into a trapezoidal cross-section and the heat flux distribution formed creates greatly improved thermal efficiency.
Crazy, huh?
