Coiled Liebig
Coiled Liebig
Just popped into my head, but has anyone made a coiled liebig condenser before? I'm thinking I could take a piece of 1/2" copper tubing and push it into a piece of 3/4" copper (or even 1" black plastic tubing). Kind of like mashing a worm and a liebig together.
I clearly haven't thought it through all the way, but thought I'd get some feedback.
If I didn't learn the hard way, I wouldn't learn at all!
Re: Coiled Liebig
Not coiled, bent. After bending, I wrapped the inner with a spiral of electrical cable the diameter of the gap then pushed clear plastic tube over it.
Re: Coiled Liebig
Were you thinking of a graham condenser..
Check the link on a graham built.. viewtopic.php?f=17&t=41674
Mars
Mars
– Albert Einstein
– Albert Einstein
Re: Coiled Liebig
Not a graham, but a jacketed worm, I guess would be closest. Maybe I’ll just make one and see how it works!StillerBoy wrote:Were you thinking of a graham condenser..
Mars
Re: Coiled Liebig
It will work alright, but the weight of it, once full of circulating water, will be heavy..Windswept wrote:Not a graham, but a jacketed worm, I guess would be closest. Maybe I’ll just make one and see how it works!
Mars
– Albert Einstein
– Albert Einstein
Re: Coiled Liebig
Myles built one about 8-10 years ago and theres some cool pics of it here somewhere . Don’t have time atm to seach it .
- Twisted Brick
Re: Coiled Liebig
I'm not so sure Myles built anything that wasn't cool. Here's the links:Yummyrum wrote:Myles built one about 8-10 years ago and theres some cool pics of it here somewhere . Don’t have time atm to seach it .
http://www.coppercustomstillcomponents. ... .php?t=146" onclick="window.open(this.href);return false;" rel="nofollow
http://forum.moderndistiller.com/viewto ... =61&t=1488" onclick="window.open(this.href);return false;" rel="nofollow
Re: Coiled Liebig
If you do a Google search for "DIY coiled counterflow wort chiller" you will get a good assortment of ideas. The beer guys use these quite a bit.Windswept wrote:Just popped into my head, but has anyone made a coiled liebig condenser before? I'm thinking I could take a piece of 1/2" copper tubing and push it into a piece of 3/4" copper (or even 1" black plastic tubing). Kind of like mashing a worm and a liebig together.
I just thought this might be along the lines of what you were thinking.
Hope it helps.
WillieP
Re: Coiled Liebig
WillieP, ya beat me to it. What you've described is a counter-flow chiller. The OP, that is
Re: Coiled Liebig
Thanks twistedTwisted Brick wrote:I'm not so sure Myles built anything that wasn't cool. Here's the links:Yummyrum wrote:Myles built one about 8-10 years ago and theres some cool pics of it here somewhere . Don’t have time atm to seach it .
LOL I scanned through 84 pages of posts that Myles had made and couldn’t find it. ( over 2400 posts )
Apparently he used photo bucket ... and the rest is history .
Yes thats the one . Cheers
And thanks for posting a real pic . Unless members are signed up to CCSC or MD they can’t see pics ..... thats one thing I really love about HD forum .... vistors can see all pics .
Re: Coiled Liebig
Exactly! I didn't think it was a new idea, thanks for the links!WillieP wrote:If you do a Google search for "DIY coiled counterflow wort chiller" you will get a good assortment of ideas. The beer guys use these quite a bit.Windswept wrote:Just popped into my head, but has anyone made a coiled liebig condenser before? I'm thinking I could take a piece of 1/2" copper tubing and push it into a piece of 3/4" copper (or even 1" black plastic tubing). Kind of like mashing a worm and a liebig together.
Hope it helps.
WillieP
Re: Coiled Liebig
Here's a link that one of the poster stated how he built his coiled liebig..
http://www.artisan-distiller.net/phpBB3 ... 8&start=15" onclick="window.open(this.href);return false;" rel="nofollow
Mars
Mars
– Albert Einstein
– Albert Einstein
Re: Coiled Liebig
That is really nice work!
I made one out of the same motivation.
Took 1 m length of 15 mm OD inside a bit shorter 22 mm OD (20 mm ID). Soldered a wire around the inner pipe, locked a 15-15-22 T on one side and bended with a bending iron. It took some strength and I was a bit rough, but it worked. When I reached the other end, I fitted another 15-15-22 mm T.
It went quiet well, but I forgot to think about the diameter of the spiral. Result was a very unpractical half-spiral that was too hard to balance. Never used it.
Can't find the pictures now, but I will post them as soon as I see them.
Re: Coiled Liebig
Found them
The black colours are made by the attempt to anneal by a wood fire.
Halfway. I wanted to make a full circle with straight bends to the left and right. But, as the diameter was much larger than I expected, it just came to this:
I should have let out the first counterbend or have taken pipes of 2 in stead of 1 m.
Now that I see them again, some 3 years later, I think of soldering another length to it and finish the curves.
The left side. Left the right side open.The black colours are made by the attempt to anneal by a wood fire.
