T500 condenser
T500 condenser
I went to clean my t500 condenser i put some water in the column and it seemed to be dripping out the other side.. at the top where the black piece bridges the larger column to the smaller column.the larger column is loose.i can't turn it. Does anyone's know what i should do about this.is it normal? I've only used it once.Yesterday.it ran perfect. So off anyone knows anything or can offer any info please do. And thanks.
Re: T500 condenser
Hi I had the same thing happen when rinsed mine. I kept an eye on it but it seemed to work ok couldn't find any vapour escaping so think you should be ok. If it's new it should have a guarantee or perhaps try the still spirit forum for further advice.
Although it is a good little still there are better options out there but I'm grateful for mine getting me into this hobby.
Hope this helps
Lee
Hope this helps
Lee
Re: T500 condenser
There is m the leak right there. Now I've not tried to use it again since then so i don't know how bad it is yet.i was thinking about getting some rtv silicone and putting a bead around it. Hopefully it's no big deal cuz I've got 5 gallons going in there tonite.and i will be upset off it don't work.i guess ìf it does start leaking i could shove it full of biscuits
[img]https://uploads.tapatalk-cdn.com/201904 ... 4900bc.jpg[/img]
