4 inch shotgun with 14 tubes 1/2”
Just a couple pics of an over built shotgun condenser that I built for reflux over my 4 inch plate column. I will put the ferrules on tomorrow when they arrive.
Re: 4 inch shotgun with 14 tubes 1/2”
Thanks LWTS. It can be a little bit tough the first time you build one or it was for me. The center disk was placed in the middle and has some 5/16 holes drill that should give about 35% of the plate surface of flow. I hope that will help pull heat into the water by adding some turbulence to it. Also I did cheat a little by hard soldering a few places so it would hold together for sealing with Harris 8.
Not a cheat if you do it to make it work. I like it, bit bigger then I would have made it but that's me. Nice job.
Thank you both. I must admit that I have always ran csst coils or copper wound. I really don’t have enough experience running shell and tube condensers and that was the driving reason to build it. I wanted to see if I was missing something that would affect the final product or smooth out the running of the still. The tubes are 6.5 inches long and with 14 of them if a surprise came up during a run I should have no problem putting the system into full reflux. My big concern is over cooling the vapor so as to nock the column out of its smooth. I am sure with some time behind the wheel I will get a better understand.
I really can not over state the amount of information on this site and the great members that put it there.
My comment on size is to reference only to it's response time to adjustment. I have stopped worrying about can I hold full reflux. I don't hold the full reflux thing on the plated column and start pulling fores as soon as the start to come over so a shorter deflagmater has a faster response. May be just my way but they all drive different.
A pic of it with the flanges on.
Nice job, she's a real beauty! Mind if I ask where you got the template and if you'd be willing to send a copy to me? In the process of getting things together to build a 4" bubble plate column and this would work great for a dephlag above it as i'll have some extra 4" copper.
-Z
-Z
As mentioned it is beautiful. AC mentioned the size, mine is also much smaller with five 3/4” tubes six inches long and I can get 100% reflux. What is that outer pipe on your condenser, looks like a handle?
The output piping is 1/2 copper. I did sweat a small piece of copper so the one to brace it so it did not bend over time. I did not have a template for it. I used a compass/dividing tool and laid it out from there. If I had a template I would be happy to send it. Also in one of the pictures there is baffle plate shown. It was set to the center of the tubes and has 37% surface area in holes for the water.
Bushman. I was hoping that by raising the output pipe slightly above the input that it would help keep air trapping in the top. I could turn it on full flow and push the air out then it would not siphon back in, I hope.
Sounds plausible Jack . Some do similar by raising the outlet hose above inlet but yours is a neater way about it
I was curious about your baffle being at the top end . Is it more a flow diverter rather than a baffle to spread the incoming water more evenly between the tubes ??
In the picture the baffle was not in place. I slid it to the center and tacked it in place with some solder I am hoping it will keep a little pressure on the water as it passes through and helps increase better heat absorption and full contact.
