Red/Blue quick connects
Smokee
Post by Smokee »
I need to fix the tubing to my dephleg and product condenser. I saw in a video I've recently watched these blue and red plastic quick-connects, pretty much like what I have on my air compressor but they're plastic. I'm using a small pond pump to circulate the cooling water, I'd love to make the connect on the still more permanent. I've been searching "quick connect" and a list of similar searches but seem to only be getting the shark bite type connectors, nothing like what I'm looking for. I think the brass connectors are over-kill for the low-pressures of the pond pump.
I'm I using the wrong term for these? I'm looking for a light-duty quick connect with barbed ends.
Jack C
Re: Red/Blue quick connects
Post by Jack C »
Look up John Guest fittings.
MtRainier
Post by MtRainier »
Here's what I use, plus some 3/8" RODI tubing and a hose-thread to push-connect tubing adapter to connect to my utility sink:
https://www.lowes.com/pd/SharkBite-3-8- ... 1000192675
It does get warm on the condenser output, and likely won't last forever, but it has lasted 2 years with no drips. It just gets harder to push the tubing in.
ID on that hose is 7mm
OD is 12 mm
