Condensing 6kw of power for a soxhlet extractor
needmorstuff
Post by needmorstuff » Thu Jul 23, 2020 1:34 am
Hi All,
I have a 26l soxhlet extractor sat atop a 100l milk can boiler.
I want to use my full 6kw of heat to speed up extraction cycles.
I am having one hell of a time condensing that 6kw and despite my efforts steam still escapes the shotgun condensors I have tried.
To date I tried a 6" with 18 x 12mm tubes, 230mm long
a 500mm long 3" shotgun with 8 x 12mm tubes - the tubes i put scrubbies in to increase surface area.
Both failed miserably - even at 3kw! I guess condensing upwards is harder than condensing for product collection.
I don't have any more height to use... and to get 500mm i have to take my boiler of its stand so draining will be hard.
Ideally I'd like a horizontal arrangement for condensing - I have looked at this https://www.aliexpress.com/item/4001115105557.html as it claims to knock down 9kw. It is only 300mm long so i asked them to make a 500mm and they tripled the price!
I have zero fabrication skills and i am in the uk.
What do you guys think is an option?
I thought maybe CSST in a 3" piece of spool with a central 3 way Tee - capped off at one end then a 3" to 1" offset reducing end cap at the other for the CSST to go through.
Or i could just buy the triple wound coil from distillex on Aliexpress and put that in a horizontal arrangement.
Help ;-)
MidnightThunder
Re: Condensing 6kw of power for a soxhlet extractor
Post by MidnightThunder » Mon Sep 14, 2020 6:36 pm
Still trying to fix this? I have a double wound CSST condenser about 11" long atop me 4" column and it knocks down all the vapor I will throw at it. I highly recommend this style and if I had anymore CSST when I did it, I would build it probably 16" long for a little extra capacity. 16" long double wound would probably knock down 9-10kw based on how mine performs.
needmorstuff
Post by needmorstuff » Tue Sep 15, 2020 3:37 am
In short no.
My 3" shotgun (8 x tubes, 500mm long) can easily condense 6kw pointing downwards in product collection duties. Stick it atop a column to try use it in "dephleg mode" and it can barely manage 3kw.
My next venture would have been CSST! so that's an excellent shout.
I have just changed what I am doing as I was chasing my tail on this.
I am now going to collect the product and direct it to an external soxhlet (33l stock pot with a siphon back into boiler)
