Trying to identify a part
- Tom Kat
I am trying to replace this part with brand new. I bought a 1/2" male fitting and it did not work. Does anyone know exactly what this is?
There's no place like home
- Windy City
Re: Trying to identify a part
It is half of a union.
Those threads will only fit the union nut and are not standard so they will only fit from the same manufacturer.
I agree with Windy . I have a few of them and they aren’t interchangeable . I am going to replace mine with triclamps
It's one half of 1/2" copper union..
But careful in trying to buy a union and only using one half of it.. 1/2" union come in different thread sizing even though they are made for a 1/2" pipe..
Mars
– Albert Einstein
– Albert Einstein
Yes 1 half of a union .....cut or sweat that one of and replace with the whole union.
https://www.google.com.au/search?q=3/4+ ... 46&bih=636
You may find a manufacturer's mark which would help in matching bits.Windy City wrote: ↑Fri Mar 26, 2021 3:12 pm It is half of a union.
- Deplorable
+1 heat the joint, and pull that elbow off your existing liebig, and sweat it onto your new liebig that you are building.Saltbush Bill wrote: ↑Fri Mar 26, 2021 4:38 pm Yes 1 half of a union .....cut or sweat that one of and replace with the whole union.
The size of the flats where you put a wrench on it varies by brand too. Some have more (smaller) flats and round off easier. If you'll be disassembling and reassembling a lot I would try to find one with large wrench flats. Nibco makes some really good ones.
Plain ole pot rig.
- Tom Kat
Thanks fellas I will get a new one and replace all of it.
Before you assemble the new one, lap the mating surfaces with a little toothpaste
to see if there are any defects in the mating surfaces, much easier before assembly.
ByRe: Trying to identify a part
A good quality stainless steel union shouldnt have that problem.
Here in Au a quality one is about $12.
Re: ByRe: Trying to identify a part
I have a bucket full of copper unions and always check fit up before assembly.Saltbush Bill wrote: ↑Fri Mar 26, 2021 7:05 pm A good quality stainless steel union shouldnt have that problem.
I'm going to have to check out the stainless ones.
Ive never seen or used a copper one.....im sure you could lap them with paste........stainless would be a different matter.
Most of you guys in Australia seem to use stainless unions, they must be more common there than they are here. I'm sure they're available online but I've never seen one in a supply house here in the US. I like the sound of it though. They have to be more durable and probably have less manufacturing defects.
Plain ole pot rig.
now we both learned something new today because i've never seen a stainless one that I can recallSaltbush Bill wrote: ↑Fri Mar 26, 2021 7:14 pm Ive never seen or used a copper one.....im sure you could lap them with paste........stainless would be a different matter.
mine are copper copper with a brass or bronze nut, and they can take damage with handling.
posting on top of River Rat.
