https://www.aliexpress.com/item/4000344 ... VWgcS&mp=1
any good, or will this just cause pooling in a VM?
2KW heater on a 2" column.
do these work?
Re: do these work?
Since the stationary coil is positioned over the take-off it will effectively turn a VM into a CM. You'll need to continually fiddle with the coolant flow to pass vapor to your product condenser.
________________
Re: do these work?
Um ... its a cross flow condenser . Perfect for a VM where limited height is a problem .
Would also work on top of Slant plate Boka .
Re: do these work?
Ah, right you are, I missed that photo showing the second end cap.
________________
Re: do these work?
thank you.
would something like this benefit from being packed with copper mesh?
Re: do these work?
Not necessary. Mesh wouldn’t increase condensing power.SpankeyBrewster wrote: ↑Mon Apr 05, 2021 8:08 am...would something like this benefit from being packed with copper mesh?
