Modifying my Liebig condenser
- Garouda
My Liebig was a Ø 10 mm vapour tube, 70 cm long inside a Ø 1" cooling jacket. It's enough to knock down vapours but in pot still setting, the product is too hot, I measured about 51 °C at my last gin run. In VM setting, it's OK, the reflux condenser does its part of the job.
Something I didn't implement having some electric wire.
In place outside the vapour tube to reduce laminated cooling water flow. I read somewhere a project with a wire inside the vapour tube. IMO it is not useful, indeed, vapour is like a hot gas where the molecules are moving randomly in all directions (Brownian motion)
First stage, disassemble the existing Liebig, I use a butane torch to do the job.
There's a problem, the Liebig is a Ø 28 mm pipe I bought in Belgium when I left the country some 17 years ago, the other pipe is a 1" I got at the university when they replaced all air conditioners, Ø isn't the same. Tin silver solder won't do the job, I'll have to use some tin lead solder which isn't a problem, it's the cooling jacket, not the vapour tube...
Good flux made in France I bought in Belgium before leaving the country."In wine there is Wisdom, in beer there is Freedom, in water there are bacteria."
Benjamin Franklin
"In moonshine there is Rebeldom"
Garouda
Benjamin Franklin
Garouda
- Garouda
Re: Modifying my Liebig condenser
All fittings that are sold online from China I got so far despite what the seller is saying, are not T2 99.9% copper, but red brass.
There's a risk of lead content, so to be used in the cooling water circuit only! I have to wait for several months from now on, it's too hot to start a fermentation, I might try some rum though...
Benjamin Franklin
Garouda
Benjamin Franklin
Garouda
