Cooling reservoir build
Hey everyone Whiskey here! I'm building a cooling res to help out my runs. I have a glycol chiller for brewing that will help pre chill the 50 gal of water. I'm adding a radiator and fan assembly to help out as well. Keep you all posted. Cheers.
"No great mind has ever existed without a touch of madness". Aristotle
- Boozewaves
Re: Cooling reservoir build
this thread might be of interest . seems similar to what you are thinking so it may be worth a look https://homedistiller.org/forum/viewtop ... 87&t=66690
Become a distiller : start here viewtopic.php?t=52975
So I got all the connections dry fit. I'm going to glue them up well tonight and do a leak test. The fan assembly comes tomorrow, more pics once I'm done. I'm excited to connect my glycol chiller and do my spirit run soon after. Keep you all posted.
Boozewaves wrote: ↑Fri Jun 25, 2021 8:09 am thank you
The successful recirculating stories that I've researched. Have a reservoir 4x to 5x larger than the boiler capacity. Even with a forced air heat exchanger. I sized mine 5.5x just to be safe.
My 9" Shotgun Condenser
This hobby really is not so much about making alcohol. But bottling opportunities to make memories with Friends and Family.
- bluefish_dist
My cooling water tanks were in the 5-6x range. Worked well as long as I didn’t want to run continuously, ie day after day after day.
I tried a car radiator. Failed miserably. They simply are not designed to do what we need. It only dropped the temp of the water by 3-5 deg f. While it may have been dumping heat, it simply would not cool the water enough to be used again. A linear radiator like a pipe with fins on it may work better vs a typical tank style like in a car. Best solution was just a huge tank of water.
Formerly
Dsp-CO-20051
Dsp-CO-20051
Been looking at doing this for a while, the 5-6x boiler size has put me off I don't have the space for an additiom 200l container. Keen to see how the active cooling going with keeping water temps down so I can stop wasting so much water.
If you are going to use Glycol , only use Propylene Glycol which is FDA approved and safe .
Never use Ethylene Glycol ( the green stuff used in car radiators ) as it is as poisonous as Methanol .
Not saying you are going to drink it , but leaks and accidents do happen .
If the radiator ends up not working. https://homedistiller.org/forum/viewtop ... r#p7443067
Depending on your set-up, you could put the 200 litre container OUTSIDE, with inlet and outlet pipes let through the wall...ash_from_oz wrote: ↑Sat Jun 26, 2021 3:05 pm Been looking at doing this for a while, the 5-6x boiler size has put me off I don't have the space for an additional 200l container. Keen to see how the active cooling going with keeping water temps down so I can stop wasting so much water.
