first shell and tube
just finished this up. 2" with seven 3/8 tubes 16" long and seven baffles. used 5% stay silv to solder everything up with oxygen acetylene then lead free soft for the ferules.
- Salt Must Flow
Re: first shell and tube
Uhhhh ... GORGEOUS ! ! !
Have you pressure leak tested it?
Curious, what's that hole drilled through the ferrule as well as the shell in the first pic for?
yes ready to go. hole is just a vent to not create a vacuum. thanksSalt Must Flow wrote: ↑Sat Jul 02, 2022 5:57 pm Uhhhh ... GORGEOUS ! ! !
- Salt Must Flow
Interesting about that vent hole. I installed a 2" Tri-Clamp end cap on mine with a hole drilled which I threaded 1/2" NPT. I installed a copper reducer and soldered copper tubing in order to direct product to my jars. In other words, I never vented the take-off and never had an issue either. It's not a criticism, but I'm curious. Do you know what that vent hole is meant for? I do not know. It can't hurt, but I'm genuinely curious as to what condition it is meant to thwart. I suspect a maybe a flooding situation.ecir54 wrote: ↑Sat Jul 02, 2022 6:32 pmyes ready to go. hole is just a vent to not create a vacuum. thanksSalt Must Flow wrote: ↑Sat Jul 02, 2022 5:57 pm Uhhhh ... GORGEOUS ! ! !
- Deplorable
Nice craftsmanship. That should bring you many years of use.
to drain a liquid needs a vent.
- Stonecutter
Effin’ A man. That is sweeeet! All copper
Congratulations
Congratulations
-Thomas Paine
-Thomas Paine
Nice build
I like the way you did the tubes so that liquid doesn't puddle on top.
Gorgeous.
- EricTheRed
Very nice.
That's going to knock down a lot of power easily.
Still also curious about that vent.
Life has gotten interesting!
Nice work
As above I'm also a little puzzled by the vent hole?.....is that just to save having one on the parrot ?
That's a better looking build than is ever likely to happen in my shed.
thanks guys forgot to add tinned the backside of the end plate heavily with soft solder before soldering the ferules. Had one of the tubes leak after installing ferule but easily fixed by applying heat to the outside the end cap to draw the solder up.
may add a parrot later off the union with a drain that can bypass it.Saltbush Bill wrote: ↑Sat Jul 02, 2022 10:24 pm Nice work
