Replacing a 5 litre boiler with a 10 litre boiler
In our view 30 gallons and under is considered hobby size. Do not bring anything larger then this to our site
Postby Rod » Sun Sep 10, 2017 6:23 pm
I have an old 5 litre STILL SPIRITS reflux still which has served me well over the 10 years
I have only a small place to run my still and would like to replace the 5 litre boiler with a 10 litre boiler
my still spirits boiler works well , but I only make about 22 litres at a time , tossing about 2 litres of trub
the still bit runs well with marbles , a recent change
the current boiler is meant to run with an internal bare element with no adjustment , , but I put a thermostat into the power feed and can control the heat
I have looked on the internet and found this
https://www.crazysales.com.au/online-10 ... OCEALw_wcB
make neutral , mainly for gin and a couple of mixers , like panty dropper
the lid looks like it may seal , the current lid on the old has a large ring with a clamp to prevent leakage
whats ya thinking , be nice :)
The Friendly Spirit
Rod
Re: Replacing a 5 litre boiler with a 10 litre boiler
Postby still_stirrin » Mon Sep 11, 2017 5:49 am
It has bakelite fittings and most probably rubber gaskets...not acceptable for hot alcohol vapors. I'd pass.
Get a 16 liter stainless stock pot and make a boiler. And a modified hotplate (thermostat replaced with a power controller) will work well to heat it.
What is a Proof & Traille hydrometer: Alcohol-meter
Enzyme info: SebStar
HD Google search info: HD Google-how to
All about mashing grains: Braukaiser
Master Distiller
Postby thecroweater » Mon Sep 11, 2017 8:00 am
you can get 25 litre boilers from any HBS or online bit if ya check eBay, Gumtree etc you van sometimes get them with or without stills pretty cheap. I got a little 5 litre one from an old ultra pure still so I'm well aware of its limitations. One day I may modify a lid to take a pots till for macerated gin but I was done doing cuts on that thing after a very short time. It was fun but it took dedication to run any mount :thumbup:
thecroweater
Return to Boilers
Who is online
Users browsing this forum: No registered users and 2 guests
