5500 watt element heating up. Sounds like a train whistle without the column on the boiler.
https://www.youtube.com/watch?v=36NYe-e_SKw" onclick="window.open(this.href);return false;" rel="nofollow
Boiler sound
Boiler sound
Sky Diving without a parachute is a once in a life time experience!
Re: Boiler sound
It's your electric element creating a steam boundary around its self.
Cold water, full power element, steam release echoing in boiler...there's a technical name for it but it escapes me at the moment!
If you "ramp" up the power slowly, the common name is Bake Off, as the water heats you can avoid this and prolong the life of your element.
This is the major reason hot water elements fail. The are either on or off.
DSP-AR-20005
DSP-AR-20005
Re: Boiler sound
You must be right....This only happens in the beginning. As things heat up it gets nice and quiet. Guess I should use less power on startup
Re: Boiler sound
gas is nice ..it just goes SHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
Re: Boiler sound
Mine sounds more like ssssssssssssssssssssssssssssssssssssssssssssssssssssssssSaltbush Bill wrote:gas is nice ..it just goes SHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
Deo Vendice
Deo Vendice
Re: Boiler sound
My gas burner makes a loud constant roar. No SSHHHHHHH about it
Using Google Search
Using Google Search
Re: Boiler sound
The effect is Cavitation; essentially there is a small but powerful shockwave produced when bubbles of steam collapse, the vibrations generated are the noise you hear.
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
EXPAT
___________________
