Keg opening question
In our view 30 gallons and under is considered hobby size. Do not bring anything larger then this to our site
Postby workpress » Wed Mar 29, 2017 4:33 pm
Hey guys I have a question with regards to a keg With a 1 1/2 " sanitary flange on it . If my column is 3" should the hole exiting the boiler be 3" as well or will the 1 1/2 be fine. I assume that vapours will rise and take the path or least resistance and all. However I am curious and would like some feedback.
Thank you
Workpress
workpress
Re: Keg opening question
Postby Truckinbutch » Wed Mar 29, 2017 5:41 pm
I stayed with 1 1/2" for a pot with thumper . Working great for me for 4 years . What's your reason for wanting to go larger ?
Truckinbutch
Postby bluefish_dist » Wed Mar 29, 2017 5:54 pm
It will work fine. The vapor speed will be faster at the opening, but will slow down once you get to the larger diameter. I run 4" on a 2" all the time.
To do it again I would go 6" for easier cleaning since my arm is too fat to fit through a 4".
Blue Fish Distillery
Dsp-CO-20051
bluefish_dist
Postby workpress » Thu Mar 30, 2017 1:50 pm
Hey Truckingbutch
My reason for asking is to find out if it will work as I was going to cut a 6" hole and put a sanitary tri clamp with a reducer to 3" and then another try clamp to my column. This is for cleaning and I just was not sure if by not making the exit from the keg larger, at least the same size as my column I would be restricting the vapour path too much. But from further reading this is not a concern for cleaning.
Workpress
workpress
Postby Truckinbutch » Thu Mar 30, 2017 2:10 pm
workpress wrote:Hey Truckingbutch
Workpress
Gotcha :thumbup: I was concerned about extra labor and material on your part . Know the direction you are heading in now . Makes sense .
Truckinbutch
Postby Swedish Pride » Thu Mar 30, 2017 11:33 pm
If it was my keg, I'd flip it and use the 1.1/2 as a drain and then weld on a 3" ferrule for thecolumn and a 4" fillport, or 6" to 3" reducer as you said, the benifit with the 3" and 4" setup is that you can leave the column on as you fill the keg up.
If you have the space to store it connected that is
Don't be a dick
Swedish Pride
Postby nuntius01 » Fri Jun 16, 2017 4:44 pm
i have a 6" and reduce down to 4" makes it super easy to clean and my times are usually under 5 hours for 14 gallons. ill include a pic
post your still pics here
viewtopic.php?f=16&t=66917
nuntius01
Postby skow69 » Sat Jun 17, 2017 6:38 am
nuntius01, that's a helluva water system you got there. But the placement of the ports on the liebig turned your 3 foot condenser into a 1 foot condenser. Move them out to the ends and it will be much more efficient.
skow69
Postby nuntius01 » Sun Jun 25, 2017 8:00 am
looks that way. but i soldered in s separator flange along the length of the 1". so flow goes down then back up and around, gives me 2 feet of with flow condensing and 3 feet of counter flow condensing.
nuntius01
Return to Boilers
Who is online
Users browsing this forum: No registered users and 2 guests
