Copper scrap in the wash?
In our view 30 gallons and under is considered hobby size. Do not bring anything larger then this to our site
Postby EventfulAnimal » Mon May 29, 2017 6:37 pm
Hi all,
I'm making rum using an all stainless pot still. I don't have any copper packing (have ordered some but could be weeks away) so I'm thinking about just suspending a bunch of old copper scrap (mostly pipe bits) in the boiler during distillation. Any thoughts? Does it HAVE to be in the vapour stream?
Thanks in advance!
EventfulAnimal
Re: Copper scrap in the wash?
Postby Truckinbutch » Mon May 29, 2017 7:24 pm
I use scrap 'boiling bits ' in the bottom of my propane fired boiler . Have always used them because of advice I got from old timers when I started here .
What works does not need to be fixed .
Truckinbutch
Postby NZChris » Mon May 29, 2017 8:06 pm
Only having copper in the vapor is not ideal.
This should answer your question. http://onlinelibrary.wiley.com/doi/10.1%20...%200450.x/pdf
Master Distiller
Postby Saltbush Bill » Mon May 29, 2017 8:07 pm
I and a lot of other distillers run scrap copper in the boiler/wash.
I believe it helps, some will tell you different.
You will still need copper in the vapor path as well in my opinion.
Postby Truckinbutch » Mon May 29, 2017 9:05 pm
Saltbush Bill wrote:I and a lot of other distillers run scrap copper in the boiler/wash.
I agree . SS boiler , thumper . All lines and condenser are copper .
Truckinbutch
Postby der wo » Tue May 30, 2017 12:36 am
Sorry for my bad English!
agitator, rummager, no more scorching grain
I often write about using chemicals like for example sulfuric acid. Some are very dangerous. Before you use them, inform yourself about what you can do to work safely with them.
der wo
Master Distiller
Postby HDNB » Tue May 30, 2017 6:10 am
Bagasso's experience in the thread that DerWo suggests is what i found with my very recent experiments. I figger he really saved my biscuits with that post and owe a debt of gratitude.
using an all SS still except 4 copper plates and i was getting awful smell. i added copper pipe to low wines for a week and it helped. then i added mesh in one of the plate sections (just loosely) and it helped more. Then i added scraps elbows to the 2nd plate and it helped to the point that i'm happy with the smell of the distillate finally.
lastly i added some pipe to the wash in the boiler and did not see a noticeable improvement over all the other copper already in place but i use it anyway. I don't put it in the active ferment.
now i drink for evil.
HDNB
Postby der wo » Tue May 30, 2017 6:21 am
HDNB,
I think Bagasso would be happy to read your success in his thread. A few posts to him were a bit rough. When reading again this thread everything still sounds a bit like vodoo. Another positive report there would help.
der wo
Master Distiller
Return to Boilers
Who is online
