Keg Type M removal of valve
In our view 30 gallons and under is considered hobby size. Do not bring anything larger then this to our site
Postby AdelaideJon » Fri Oct 27, 2017 11:45 pm
I just though i would share a how to remove the Type M fitting as i couldn't find it on here.
I took the pictures after removal unfortunately, but anyway - here it is.
<<image 1 was too big refer to URL>>
remove the rubber ring with a screwdriver.
This will also release the pressure inside.
<<image 2 was too big refer to URL>>
There will be a spring in here but look past that to the centre column. Note the holes in it.
Use these holes to get a nail punch (or maybe a sturdy screwdriver) at an angle an hit with a hammer. The idea is to make it spin CLOCKWISE. It will then drop into the keg and is free.
You can then use the hole on the outer/larger ring on the main bulk of the valve to make that spin ANTI-CLOCKWISE. Then everything is free and just wiggle it out.
<<image 3 was too big, refer to URL>>
This is a side view so you know what you're dealing with.
https://imgur.com/a/tZ0zC
Cheers,
Jon
AdelaideJon
Re: Keg Type M removal of valve
Postby thecroweater » Sat Oct 28, 2017 6:34 am
not sure what ya done but you photos didn't load. Probably the safest way to release the pressure that I know is put a socket on the spear and use something like a crowbar or tyre leaver to depress it, face full of stale beer is not cool. I remove the seal and circlip and turn the spear out of the cradle then as ya say belt a screwdriver in that hole to loosen and unscrew that spear cradle. If ya don't mangle the seal to much you can re-seal with it or solder a disc in it to re-seal for aging in
thecroweater
Postby Saltbush Bill » Sat Oct 28, 2017 2:08 pm
thecroweater wrote:, face full of stale beer is not cool.
You don't have that problem if you lay the keg on its side. You can then sit on the keg while degassing it.
Postby AdelaideJon » Sat Oct 28, 2017 4:44 pm
https://i.imgur.com/XfPDosA.jpg
https://i.imgur.com/Pp8HZmo.jpg
https://i.imgur.com/apJyNqO.jpg
Yea this type does not have a circlip. It is different to others described on here.
Hopefully these images work? if not i will compress and upload direct
AdelaideJon
Postby thecroweater » Sat Oct 28, 2017 4:59 pm
This is not the coopers and West End kegs made in Belgium? Sure looks like em.
thecroweater
Postby AdelaideJon » Sat Oct 28, 2017 5:11 pm
Hi CrowEater,
Yea it was a west end one i think.
AdelaideJon
Postby thecroweater » Sun Oct 29, 2017 3:21 am
OK yeah ya got it but if ya wanted to remove the spear from the cradle there is a circlip under seal just another way to go about it :thumbup:
thecroweater
Return to Boilers
Who is online
