If you’ve got a big lid on your boiler or thumper, how are y
raketemensch
Post by raketemensch »
I am seriously considering building out a thumper,mainly to get away from squeezing grains. So ideally the keg would have a pretty big opening for dumping the sludge...
I’ve not made flour paste for years now, and don’t want to start up again.
I’ve got a good metal worker who could handle cutting whatever I need, I’m also considering doing a 6” ferrule, or even just picking up an 8-gallon milk can boiler.
What’s working well for you?
Re: If you’ve got a big lid on your boiler or thumper, how a
A 6” ferrule works good
Using a water sealed lid also works but can't hold back very much pressure
ShineRunner
Post by ShineRunner »
I flipped my keg over and use the 2” port for a drain. I use a butterfly valve on that. It will occasionally clog on draining (after steam stripping goopy corn), so I have a poker stick (dowel) to stir it and break up clogs.
I put a 4” triclamp on the top and use a 4-2” reducer. In retrospect, I would go 6” as I can barely fit my arm in the 4” and have fairly small arms.
Shine0n
Post by Shine0n »
Got me thinking more about a large opening for mine. That bastard is heavy by the end of a run and tipping is getting old.
Shady, what do you use to seal the copper to the ferrule? I like that idea :thumbup:
Shine0n wrote:Shady, what do you use to seal the copper to the ferrule? I like that idea
A tri-clamp seal
I have a large opening on my essential oil still made from an antique milk can. I made the following gasket and it works great.
viewtopic.php?t=24199
Kareltje
Post by Kareltje »
I also have a large opening on my thumper and use a large funnel to fill it.
I have a lid to screw tight on the opening with a one-hole-thumper-throughput.
raketemensch
Thanks guys, I think I’ll go the 6” ferrule route, assuming I can find one... eBay was elusive last night, I’ll dig around some more.
Now I’m wondering if I could re-use the material cut from the keg for the 6” ferrule to build a cap for it, using the existing 2” regular keg ferrule, plus a second one welded to the side. Having full 2” tubing in and out would be sweet, I think.
bronctoad
Post by bronctoad »
I can't find my link :oops: but the 6" ferule, 6x3 or 2" reducer and clamp from glacier tanks is "top shelf" :shock:
as I've read here several times buy once cry once :thumbup:
just tried to find any link to where I got my parts and only came up with home despot links.
sorry for wild goose chase :oops:
raketemensch
No worries, I ended up on their site last night because they carry 6” PTFE gaskets.
