Hi There all..
I am looking for tips on stripping lead joints out of an old copper boiler tank that I got hold of. I am building a 10 gallon boiler/potstill
Please help if anybody could?
deconstructing a old copper boiler to replace lead joints
Re: deconstructing a old copper boiler to replace lead joint
Unsolder all the joints and wet sand off the old solder with 80 grit
Don't get any on you
- Fiddleford
Used to work at a gun range
we would wet the lead so
A. we breaks our backs
B. we don't breath any of it in
I would suggest to give not only the solder a sanding
Do the whole rig just to be safe
When it's blue your true when it's red your dead
A radical way to do it, and remember I am NOT a metal-worker;mountainjack wrote:Hi There all..
Cut out the old soldered joints and start again with new, safe solder.
Also if you cut out the solder joints,
the pieces won't fit back together
Yeah, I wondered about that.shadylane wrote:Can't do it that way, it's too easyThe Baker wrote:mountainjack wrote:
Thanks to every member that gave advice. After testing the boiler I have been informed the joints are lead-free, and was welded by a machine using coppaflow, a non-toxic solder used for drinking water tanks.
I now have build the thumper and I am busy with the boiler hood and lyne arm assembly. Please can somebody point me to the correct thread where I may find out how large the thumper must be, compared to the boiler or still tank?
Also, how large the slobber box should be?
