Looking for boiler input
I wound up getting a full barrel keg to turn into my boiler. Before I start poking holes I figured I would try to get some input from the group to see if there is anything that I’d want to add now before it goes under the TIG.
First off it’s 33 gallon, but with headspace we can call it 30 gallon or less. Diameter is about 21” and height is around 25”. It has a 4” ferrule on top and a 1.5” drain about two inches off the bottom. I plan to add a couple 2” ferrules in the 3-4” range off the bottom, cutting the ferrules to have them run semi parallel. I could go a little lower if it’s a benefit other than volume, I have a smaller boiler for lesser charges. I plan a 2” fill port on top.
I’m building a controller box that will run each element independently. A DSPR1 to one element for variable control and a DSPR400 for the other element that allows both PID and variable control. The only reason I’d use the PID would be for something like butter rum to hold temp for a couple hours and then distill the next day. I’d like to install a 1/2” NPT for PID sensor and possible boiler thermometer. Should this be mid boiler level?
Being my last boiler build is there anything that I’m missing that I should add?
Re: Looking for boiler input
That's huge.
Half as big again as my 18 Imperial gallon keg. (81 litres).
I have turned mine upside down to use the ferrule as a modular drain connexion. (And put a four inch ferrule in the top).
You have a ferrule low down, can you use that one and a half inch fitting for an element or is it too small?
This one already had a 4” top and 1.5” drain when ordered. Here’s the link to give you an idea of what I’m working with.The Baker wrote: ↑Mon Dec 28, 2020 7:01 pm That's huge.
https://www.gwkent.com/33-gallon-keg.html
I’m just wanting to try and build in everything that I might want on the first go round. Handles would be nice for moving it about.
I'd put a 1-1/2 or 2" drain on the very bottom.
Use the "1.5” drain about two inches off the bottom" for a heating element.
Add another heating element that's 3"-4" higher and 90 degrees from the first heater.
And put in a 4" fill port.
- Twisted Brick
With such impressive volume, it would be really handy to have a thermometer to tell you how far/close the still charge is to coming online or your internal temp on extended heat-ups.
That and some wheels to roll that beast around on!
Was going to suggest wheels but TB beat me to it.
Put caster wheels on mine not long ago......makes setting up so easy.....best thing Ive done in a long time.
With the current wheel setup I have getting a bottoms drain would be a hassle, and the bottom ring doesn’t have much clearance to allow for a drain. I’ll look again when I get home.
I could install both elements at 2” off bottom running them semi-parallel. Is there a benefit of having 90* elements at two heights vs both on the same level? I’ll look at the 4” fill port. The funnel I currently use sets in a 2” nicely, but I can see the 4” being handy at times.
Anything Ive ever seen on any forum that has any idea indicates that the lower you get your elements the better and having two at the same level isn't really a problem if you have room to do that and they don't touch.
Thanks, Bill. I’ve coped out a couple ferrules to get them side by side without any issues. Now it’s time to decide if I need a fill port larger than 2”, and if I want a upper window.Saltbush Bill wrote: ↑Tue Dec 29, 2020 4:09 am Anything Ive ever seen on any forum that has any idea indicates that the lower you get your elements the better and having two at the same level isn't really a problem if you have room to do that and they don't touch.
I would suggest to make the fill port as big as you could. I am preparing to build mine about the same size. And I am looking at a 12” fill clean out on top. After haveing a small fill port on my old one. I am not going to deal with that anymore.
The largest I could fit on the top without interring with the 4” center ferrule and have clamp clearance would be 6”. I use this funnel. http://www.walmart.com/ip/Hyper-Tough-G ... /775595507 And it rests in a 2” ferrule very well.Prairiepiss wrote: ↑Wed Jan 06, 2021 4:39 pm I would suggest to make the fill port as big as you could. I am preparing to build mine about the same size. And I am looking at a 12” fill clean out on top. After haveing a small fill port on my old one. I am not going to deal with that anymore.
I hate funnels. I personally want to be able to pour right from a bucket into the fill port. So if I can have a big enough hole to do that. That’s what I am going to do. Don’t have to wait on the funnel to drain. Just pour away. And if you can get a 6” on it. That’s what just a bit smaller then the mouth of that funnel? I use that funnel daily for used oil in my service van. And I hate the fact I have to use it.
Not to mention a bigger hole makes it a lot easier to reach down in there if you need too.
Just saying. If you are going to do it. Make it so it makes your job easier in the long run.
- Deplorable
+1 you WILL have to get your arm in there at some point and scrub the bottom. Best to have a hole big enough to get all the way in to your arm pit, and still see what you're doing.Prairiepiss wrote: ↑Wed Jan 06, 2021 6:33 pm I hate funnels. I personally want to be able to pour right from a bucket into the fill port. So if I can have a big enough hole to do that. That’s what I am going to do. Don’t have to wait on the funnel to drain. Just pour away. And if you can get a 6” on it. That’s what just a bit smaller then the mouth of that funnel? I use that funnel daily for used oil in my service van. And I hate the fact I have to use it.
Thanks for the input, gentlemen. The funnel measured 8” across the short side, but decided to add a 6” fill. Here’s the preliminary layout.
It's a good thing that full barrels are expensive else I might be very tempted for no good reason at all.
- Twisted Brick
That's gonna be sweet, 30xs. I had a 6" ferrule installed in the last year and you're gonna love yours.
throw another 2" ferrule on the top for an agitator. stirred mash makes better likker.
now i drink for evil.
