Turbo500 Control Question
New and dumb. Got the T500 strictly because of the all in one electric boiler. Built a column myself rather than the reflux column they make. I'm curious if anyone has any suggestions for a plug n play voltage controller or PID to have a little more control over my speed when running. Thanks in advance
Re: Turbo500 Control Question
If I remember correctly the heating element on that thing is on full blast the whole time. So there is no controller out there that will make it go any faster. You could find one that would control the heat you put in so you could run a pot still head.
And forget about PID. They are temp controllers. And you can’t control the temp. The alcohol does that.
Google search....."DIY Controller Kit" .....there is one that pops up for around $50 Au.
Never had trouble with the one I own. More than one person distributes them in the world if you hunt around a bit.
There seems to be a lot out there that are way over priced ..research before you buy.
- Danespirit
Here is a dirt cheap and reliable solution.
https://www.ebay.com/itm/AC-220V-5000W- ... SwjXRXalcw
I use one of those and haven't had any trouble with it for years now.
Another take on it is the one I fabricated.
Here you are: https://homedistiller.org/forum/viewtop ... 85&t=58011
If you buy such a device pay attention to the wattage. It's a lot better to buy one that is a little over-dimensioned for the job than to have one that runs hot on you all the time.
+1 on the advice to forget about the PID.
It will only add a lot of variables to the equation and make your beginnings harder.
Once you've grasped basic knowledge about this hobby you can play around with these things.
Definitely shooting for slowing it down.Prairiepiss wrote: ↑Tue Jan 19, 2021 1:48 am If I remember correctly the heating element on that thing is on full blast the whole time. So there is no controller out there that will make it go any faster. You could find one that would control the heat you put in so you could run a pot still head.
Not sure where you are in the world. Little easier to recommend something if we know what part of the world you are in.Purd Huply wrote: ↑Tue Jan 19, 2021 8:38 amDefinitely shooting for slowing it down.Prairiepiss wrote: ↑Tue Jan 19, 2021 1:48 am If I remember correctly the heating element on that thing is on full blast the whole time. So there is no controller out there that will make it go any faster. You could find one that would control the heat you put in so you could run a pot still head.
Prairiepiss wrote: ↑Tue Jan 19, 2021 10:37 amPurd Huply wrote: ↑Tue Jan 19, 2021 8:38 amNot sure where you are in the world. Little easier to recommend something if we know what part of the world you are in.
The States
In my opinion its hard to beat the ones from Still Dragon.....a good product at a reasonable price.
I'm sure they have a supplier there.
