Sheet comes in rectangles.
Seems like it would be a lot more efficient to build box tanks than barrels.
Are round tanks just a tradition?
Why Round?
Re: Why Round?
less welding on a cylinder than a cube. rolling metal is easier than braking it.
now i drink for evil.
Re: Why Round?
geometry.. got it. didn't think about welding labour or consumables.
Re: Why Round?
Round stills don't flex as much as flat sided boilers if you are running a thumper or don't like the huffing that you already get from most round boilers, (which will be exaggerated by having flat sides).
Other than that, use what you've got. Submarine stills aren't round and produced a lot of moonshine in their heyday.
Re: Why Round?
Round is a more even distribution of heat when heated directly underneath
Re: Why Round?
In addition to the above comments ... round is easier to clean.
________________
Re: Why Round?
I'd also say most cooking pots are round. Probably evolved from there.
I have seen some old rectangular still pots that they called box wagon stills. fit in the bed of a box wagon.
Don't let your meat loaf.
Re: Why Round?
For all of the simplicity and natural advantages of round, if you aren't set up for large scale vessel construction it can be difficult to produce.
At that point squarish becomes easier to execute.
Re: Why Round?
https://homedistiller.org/forum/viewtop ... 16&t=67640
Check out the Casey Jones Distillery - they use a rectangle "coffin" shaped still
I come real close to building a square still.
My 9" Shotgun Condenser
This hobby really is not so much about making alcohol. But bottling opportunities to make memories with Friends and Family.
