mason jar lids
Re: mason jar lids
Postby raketemensch » Wed Jun 15, 2016 9:36 am
yakattack wrote:Oak lids for the mason jars are a decent idea. And had been done but if your making enough that your considering this why not make some badmo barrels. Easy to do, cheap and work a treat apparently. Just my 2 cents mind you.
Yak
I've not really done much joining, and my cuts are so bad that I'd be leaking everywhere. Know thy limits :]
But lids could be made with a holesaw, and honestly, I'm thinking they might make a decent product to sell.
MichiganCornhusker wrote:Not a bad problem to have. :lol:
Tell that to my wife :] "Why is this cabinet overflowing?"
I keep everything in a cabinet above the oven so that it gets heating/cooling cycles, but it's almost full now. I'm gonna need a new solution.
raketemensch
Re: mason jar lids
Postby cranky » Wed Jun 15, 2016 11:21 am
raketemensch wrote:But lids could be made with a holesaw, and honestly, I'm thinking they might make a decent product to sell.
That's what Corene1 did I think she used 2 different size hole saws one to make the thinner part that sits on the rim and another for the larger outer cut.
raketemensch wrote:I keep everything in a cabinet above the oven so that it gets heating/cooling cycles, but it's almost full now. I'm gonna need a new solution.
I'm in the same place, I just cleaned out one of my booze cabinets and moved everything to my booze shelf in the closet, now I'm looking at that shelf and wondering if the screws I used to mount the brackets are good enough to hold all that weight. :problem:
Sometimes I pretend to be normal but it gets boring so I go back to being me
A message to new members
We want you to be safe and succeed so start here
My Simple Controller
My Apple Brandy Recipe
cranky
Re: mason jar lids
Postby pfshine » Wed Jun 15, 2016 12:03 pm
pfshine
Re: mason jar lids
Postby corene1 » Wed Jun 15, 2016 4:31 pm
There is a bit of the description of the lids I make earlier in this thread , this is the original thread and there is some good discussion in it about various types of lid seals, viewtopic.php?f=4&t=44034
My final lids are made of 1/2 inch thick white oak toasted to 350 then the final shaping is done. I use a lathe to cut the lip but I don't see why you couldn't use a router and a hole saw. The 1/4 inch hole in the middle is to mount it on an arbor and is plugged by a oak dowel when in use. Here is the final lid. After a while you can see the staining on the wood where the vapors have been transferring in and out, and they fit both the quart and half gallon wide mouth jars.
These are all 1/2 gallon jars
corene1
HD Distilling Goddess
mason jar lids
Postby raketemensch » Wed Jun 15, 2016 4:33 pm
pfshine wrote:http://homedistiller.org/forum/viewtopic.php?f=15&t=60871&p=7402281&hilit=Hack+barrel#p7402281
Thanks man, that's good stuff.
My router table is currently keeping my UJ barrel up off the basement floor...
Oh, and thanks Corene, you posted while I was typing, that's perfect.
raketemensch
Re: mason jar lids
Postby KeenPin » Sat Feb 25, 2017 8:12 pm
Why not just use this between a jar lid and jar? Cut it with scissors (which i assume everyone has) and BAM your done.
https://www.amazon.ca/Slick-Sheet-Ptfe- ... ptfe+sheet
I'll wait for the flaming to come!
Unless you have some of those awesome oak lids! My wife will kill me if i buy a lathe. She's into beer (big nerd and science geek!) but helps with me developing a wash to make sure everything is clean, properly balanced, and such. She might not drink what I will make, but she knows what I did wrong!
Transplanted southern redneck in the north.
Now I just need to get back to "My Island!"
KeenPin
Re: mason jar lids
Postby Snackson » Sat Feb 25, 2017 8:42 pm
KeenPin wrote:Why not just use this between a jar lid and jar? Cut it with scissors (which i assume everyone has) and BAM your done.
No flaming, PTFE is acceptable. Look back through and you'll see a links to disks already cut out.
Snackson
Re: mason jar lids
Postby cob » Sat Feb 25, 2017 8:48 pm
I'll wait for the flaming to come.
you'll not get flamed for recommending lab grade PTFE.
that is the thinnest PTFE I have seen so far, and should work well.
posted with snackson
cob
Master Distiller
Re: mason jar lids
Postby KeenPin » Sun Feb 26, 2017 8:16 am
Yeah, I don'e expect a flame, was trying to be funny, which my wife tells me I'm not!
But it is supper thin and I am going to get some for the top of all my jars. Might also work for some other spots on the still too.
KeenPin
Re: mason jar lids
Postby FreeMountainHermit » Sun Feb 26, 2017 8:26 am
KeenPin wrote:But it is supper thin
Wondering how flexible it is.
Blah, blah, blah,........
FreeMountainHermit
Re: mason jar lids
Postby KeenPin » Sun Feb 26, 2017 10:07 am
I ordered it today with some other things i needed. I will post pic's and information once I get it.
KeenPin
Re: mason jar lids
Postby buflowing » Sun Feb 26, 2017 11:45 am
Might want to be careful with really thin ptfe sheet.
I use 0.04 inch thick for mason jar lids. When used with just the ring to hold them on, the ptfe disks are permeable to our spirits. I can see it by the abv drop over time.
Want to see something freaky, take some ptfe tape and soak it in some high proof. It will go clear on you. I think what's going on is the spirit is soaking all the way through and the ptfe loses its opacity.
If you are putting a plastisol coated lid on top of a thin ptfe sheet, what gets through the ptfe might solvate the plastisol and perhaps carry some evil back over to your drink.
To be on the safe side, when I'm done contributing my angels share and add a lid on top of my ptfe disk to halt losses, I keep my jars upright and do not shake them.
buflowing
Re: mason jar lids
Postby Down_Home52 » Fri Nov 10, 2017 11:21 am
Interesting reading. Is anyone offering the oak lids commercially yet? I use the ptfe discs and flip the lid over so the plastisol is up. I store them upright and have checked the lids under the ptfe for any signs of corrosion or other nastiness on the plating. Nothing there. I have stored as high as 160 proof. If you leave the plastisol down it dissolves.
Down_Home52
Re: mason jar lids
Postby ShineonCrazyDiamond » Fri Nov 10, 2017 6:52 pm
Get rid of the lid all together, and just use the ptfe. I can get mine airtight, But back it off a little for pressure relief.
Shine on you crazy diamond."
ShineonCrazyDiamond
Re: mason jar lids
Postby cob » Fri Nov 10, 2017 8:45 pm
I thought gore-tex was made from something else but according to this it is another form of EPTFE
https://en.wikipedia.org/wiki/Gore-Tex
cob
Master Distiller
Re: mason jar lids
Postby buflowing » Sat Nov 11, 2017 5:33 am
Teflon lids breath quite a bit. Check your ABV over time and you will see. I think they are more permeable to alcohol than water since I always get an ABV decrease, unlike my barrels, where it will go up or down depending on the RH. I use them as a way to air my spirits for awhile, then cover the Teflon with the metal lid to halt the loss.
buflowing
Re: mason jar lids
Postby angus_young » Wed Feb 14, 2018 7:12 pm
I am not trying to reinvent the wheel but with the shipping, those pre-cut PTFE lids will cost me some money. Do you guys think this will also do a fine job?
https://www.amazon.com/Teflon-Sheet-Pre ... flon+sheet
Thanks a lot for your help!
angus_young
Re: mason jar lids
Postby SaltyStaves » Wed Feb 14, 2018 7:37 pm
angus_young wrote:I am not trying to reinvent the wheel but with the shipping, those pre-cut PTFE lids will cost me some money. Do you guys think this will also do a fine job?
Probably PTFE coated E-Glass. Can't say what the long term performance will be, but if the coating is compromised, you don't want fibre glass in your booze.
SaltyStaves
Re: mason jar lids
Postby angus_young » Wed Feb 14, 2018 7:57 pm
Thanks for the comment SaltyStaves! I guess I will go ahead and order the ones from usplastics.com
angus_young
Re: mason jar lids
Postby Swedish Pride » Thu Feb 15, 2018 12:22 am
i use this, 0.3mm ptfe sheet cut to size, works good
https://www.ebay.ie/itm/PTFE-Teflon-Fil ... 2749.l2649
Don't be a dick
Swedish Pride
Re: mason jar lids
Postby esxman » Thu Feb 15, 2018 1:02 am
I think you are all right to be concerned about plastics . Here the mason jars ( up to 2 litres) come from Italy , and I read the tag on them , it clearly says "not suitable for alcohol above 22% ABV " .In the same supermarket they have glass carboys 2 and 3 litres , with a cork stopper ! .I shall be using these in future for long term bulk storage of product .I think you are all right to be worried about every day use of plastics in our food and drink .
For instance the aluminium problem , plastic lining in tin cans -- they say don't buy tomatoes in tins , as the acid can let the plastics leach out.Plastic wrapping in fast food , there is Bisphenol A in nearly every plastic , flagged as a possible carcinogen .With all this good information on our forum , I am sure everyone's product beats the industrial stuff hands down .Keep up the good work friends esxman
esxman
Previous
Return to What Not To Use/Do
Who is online
