using pot still as pressure canner
Anybody tried that? Temps have to reach 240, which I believe I can do. My small still is actually an old copper double boiler
"Virtute et armis" By valor and arms
Let's keep our country free as God has given us.
"Give me Liberty or Give me Death."
Re: using pot still as pressure canner
I don't know that putting a still under pressure is a particularly good idea, they are usually built to be able to withstand atmosphere, not pressure.
If you are planning on making a bomb, of course this would be a good way to go about it, although, you may find yourself in the Darwin Awards for it.
I don't like the sound of superheating water to 240 dF in a vessel not designed specifically as a pressure vessel, but you will need to know what pressure exactly you are going to generate and obtain a "Blow off valve" set to that pressure (like the weights on a "Proper" pressure cooker)
Before you do though, get hold of a "pan-tylpe " PC and bring it up to 15 psi, then lift the weights off and see what a leak would look like
This is how evolution works!
Or, more appropriately.....”natural selection”.Kareltje wrote:This is how evolution works!
Don't do it! A decent pressure cooker does not cost that much. They can be found used at garage sales for pennies on the dollar.
Living life one drop at a time
I ain’t here for a long time, I am here for a good time
Don’t worry, have a bourbon!
https:// http://www.youtube.com/watch?v=6Hlw_xxx9ldTh" onclick="window.open(this.href);return false;" rel="nofollow Admin edit off topic post
this is bad advise dumping a pressure cooker at full pressure (pulling the weight) isPikey wrote: Before you do though, get hold of a "pan-tylpe " PC and bring it up to 15 psi, then lift the weights off and see what a leak would look like
at the very least dangerous.
- Skipper1953
Would you care to expand on that? Is there something to be concerned about other than the scalding jet of steam that will come from the vent when the weight is lifted?cob wrote:
Not a good idea .Ya take the pressure off in some canning pot with food in it could cause food to blow through with steam .If your canning in glass jars breakage and again spewing steam and possibly food.If it happens and was heated unnoticed stopped up ya have a bomb . Moving to what not to do and locking.
