Modular Thumper / Steamer Build
Re: Modular Thumper / Steamer Build
Hillbilly Popstar wrote:Well I want to build a still that would do this. I have an 8 gallon milk can boiler now, I'd like to use it as the thumper and get the 26 gallon milk can for the boiler. I think that would be a good ratio.
But they don't give those 26 gallon milk cans away...
Maybe I should start a new thread about this and try and word the process a bit better.
You meant to say 25 gallons... :ewink:
Hillbilly Popstar
Post by Hillbilly Popstar »
Well I surely wouldn't overfill it.
So make that 20 gallons and we're square right?
"Making likker with a hydrometer and thermometer is like measuring the length of a 2x4 with a clock"
Hillbilly Popstar wrote:Well I surely wouldn't overfill it.
Just making sure you're adhering to Rule #10... :ewink: So it's a 25 gallon boiler unless you're a legal distillery... :eugeek:
Hillbilly Popstar
10-4
ShineRunner
Post by ShineRunner »
Where did you get your corks? What size are they?
I got some size 30 from widgetco but they're a touch small and sit in too far for me to be comfortable with them. They're also layered, which I thought was a no-no for glue? I had a hard time getting them to seal on the cleaning run.
I ordered size 32 from home derpot and the picture showed solid but it's conglomerate cork. Pretty sure that's a no go. Guess I'll order size 32 from widget?
SR
MichiganCornhusker
Post by MichiganCornhusker »
I don't remember where I got the corks.
I know I just found them online, maybe searching "natural cork"?
They are solid, real cork, no laminating or composites. They work great as they swell a bit when hit with hot vapor.
I've noticed a little wear and tear on them do I might be wanting to get another pair soon. If I can find out where I got these I'll let you know.
ShineRunner
Thanks. I found these: https://www.onlinesciencemall.com/produ ... nches-each" onclick="window.open(this.href);return false;" rel="nofollow
They mention that they're pressed and no glue. I emailed widgetco to see if theirs are the same. Problem with the widgetco ones is that there are some gaps in the cork right at the level that I need them to seal. I think if they were a little bigger, I'd have more room to push them in, if necessary, and still have room to grab onto them and pull them easily.
I'll also update when I hear back..
I'm excited to run this thing and glad you came up with a modular design!
SR
MichiganCornhusker
These look just like the ones I have:
http://www.corkstore.com/Products/Bark-Top-Stoppers" onclick="window.open(this.href);return false;" rel="nofollow
Just a thought
Where there's only water vapor, and no alcohol vapor on the material
Most food grade material, that can take boiling water, probably would be acceptable for seals.
ShineRunner
Shady, the corks will be exposed to alcohol vapor as it plugs both the boiler and thumper pipes. The cork is also present on all regular still runs as well.
I got a response form widgetco about their layered corks. "The process uses a food grade polyurethane…it should withstand heat above steam temps" obviously, food grade or not, not sure I want polyurethane in my drink. One of the layers of my cork has already delaminated and fallen off. I've only done vinegar and sacrificial runs to this point. I didn't see any signs of glue on the piece that peeled off, but it must be there..
I reached out to the link I provided- onlinesciencemall. They repeated their description that there is no glue, and that the cork is held together by the pressure of being formed together. I ordered some and will check them out. We'll see. I'll let you all know what it looks like when I get them.
SR
ShineRunner wrote:Shady, the corks will be exposed to alcohol vapor as it plugs both the boiler and thumper pipes. The cork is also present on all regular still runs as well.
SR
"Food Grade" does not equate to "alcohol safe", especially high proof alcohol... Only solid cork will withstand high proof alcohol liquid or vapor, heated or otherwise... Any cork made from compressed granules will have the same problem in that they will fail in short order...
Midwest
Post by Midwest »
MCH thought I would freshen up this tread with a couple of questions for you about you steam rig. I am currently steam mashing so the next logical step is distilling.
1. What further modifications have you made, if any, to the original design. I like the layout of you steam rig and since I started doing all grain I can see the benefit of steaming the thick gooey mess that is left after the clear is racked off. Even after letting it settle there seems to be a lot of wort trapped in the trub.
2. Are you still using the 1/2 over 3/4 Liebig?
3. Do you use water or clear wort in the steam pot?
I assume you are draining your lees off with the 600 micron barrel filter. When I use the filter it does a good job of removing a large portion of the fluid but I find that there is still quite a bit retained in the grain. When i put a little pressure on the grains with the spatula i get a fair amount of fluid. Am i miss understanding it and you are leaving the grains in there also when you distill?
4. With your design would there be any benefit to using a 2x2x2 tee at the take off fitting on the thumper/second pot and utilizing a 2" shotgun condenser instead of the Liebig.
5. On the steam arm in the pot, you put an L pipe with a series of holes drilled in it, Is that still effective for you? On my steam masher I utilize a stainless steel hose mesh. Do you think there is a benefit of one over the other?
6. When you ordered the ferrule's to connect to the 3/4 inch pipe were they 2" ferrule and what was the other end? threaded, non-threaded?
Thanks, Any updates will help. Your layout seems straight forward
MichiganCornhusker
No mods, it has worked out really well as-is. It is super easy to set up and tear down, and in a bucket the parts don't look anything like a still.
You're right about the trub, it does contain a lot of alcohol. I usually get about another 25% low wines by being able to strip the muck.
Yep, works great. 3/4" over 1/2", 34" inlet to outlet, no crimping, no turbulators, no scrubbies...
I crank the heat up full on my burner and strip at about 2 gallons/hr.
These days I just fill the boiler with water so that there is no danger of scorching. That way I can run full tilt heat without a second thought regardless of grain bill.
I've stripped grains and all but the grains make up a lot of volume so it means more runs. They also take up a lot of room in my fermenter, so I've gone to filtering the grains out before fermentation just so I can fit more juice in the Brute.
Stripping grains and all will definitely give you maximum extraction, but I do remember the low wines from the grain slurry being pretty dang funky. Cleared up in spirit run though.
Yes I still use the barrel filter, I think I'm using 600 micron, or the 400. It's fairly coarse but it gets out most of the grains and does so quick and easy.
I do a quick strain with the filter and collect the grains in buckets. Then I add some water to the grains and mix them up again and re-strain. I get quite a bit more out of them this way. They are pretty dry and spent when I toss them.
I think this is a version of batch sparging. I mash for a higher SG to allow for the added sparge water.
Not for me. As I say, my liebig was cheap and easy to build and works well at my max heat. I do like the looks of shotttys but wouldn't go through the extra effort and expense myself.
I know it works but have nothing else to compare it to. An open pipe might work just as well, and the mesh hose might work better somehow, I just don't know.
I used 2" at the kegs and either 3/4" or 1" for the 3/4" pipe. I forget the size for the pipe but they allowed the pipe to slip into the ferrule and they were a close enough fit to solder without any other mods.
I spent a lot of time keeping notes as I read through this site, none of the ideas were mine, everything stolen! So I have no problem saying that it is a brilliant setup, it has served me very well.[/quote]
Midwest
Post by Midwest »
MCH I can't thank you enough for the response. I would not have though of adding a little water to the strained grains and re-straining them again. I will definitely do that on the next batch. I asked about the Liebig as I currently run 5500 watts on my pot and it seems to knock it all down well. I did get some huffing on the last whiskey run until I added a piece of copper screen to the end of it. So as I understand it you are putting all of your wort, yeast trub and all, in the second pot and steaming away. Sounds so much easier that racking and straining. As I move forward I may have a couple more questions. Again thanks for the quick response!
BlackStrap
Post by BlackStrap »
I've been searching, maybe I'm not using the right lingo...Anyways finding this is awesome, and inspiring.
If you don"t mind MichiganCornhusker have a couple questions though.
How many elements and what size are they?
How long does it take to bring both kegs up to temp to start producing?
How much "slop" do you start with in second keg?
The one who cuts the firewood gets twice the warmth
MichiganCornhusker
I'm using an old turkey fryer burner for heat. With water in the boiler though, this would be a perfect place for electric elements, I just haven't gotten around to switching over.
I put about 4 gallons water in the boiler and about `10 gallons of ferment or slops in the thumper.
It takes about one hour for everything to come up to temp and start producing.
What I do these days is when the fermentation is finished and has sat for a few days, I transfer everything out of my 50 gallon Brute into 5 gallon carboys.
By pouring the ferment through a funnel into the carboys it degasses the liquid and it will settle out pretty good after a couple days.
Then I rack off all of the clear liquids and collect all of the slop in separate carboys. I usually end up with about 70% clear, 30% slop, and the slop is very thick.
At this point it would be pretty safe to charge the boiler with the clear and put more clear or slop into the thumper, but I use water in the boiler just to not have to worry about scorch.
A typical run will use up 3 gallons of boiler water, sometimes more if I'm trying to get the overall proof of the low wines down to 30%.
Wild Bill
Post by Wild Bill »
Mch, your rig intrigues me to no end and I may end up modding my build or building a completely new setup based on your build. My wort is very clean as I use my false bottom mash tun to filter out most solids. I also mostly ferment in half barrel kegs. This leads me to a few questions. Is there any reason not to just hook up keg with fermented out contents right into thumper configuration and run? Would maybe degassing with a drill and paddle arrangement first be adviseable? Is there a small stub of 2” pipe between the tees on top of thumper keg? Great build anyhow but I just barely got my feet wet and I can see now you are going to cost me more money!
Living life one drop at a time
I ain’t here for a long time, I am here for a good time
Don’t worry, have a bourbon!
lil misfit
Post by lil misfit »
:clap: absulutely awesome!! you've put together what i've been trying to get all the parts to do. teamed up with a mash steaming set -up. congrats very well done :thumbup:
Truckinbutch
Post by Truckinbutch »
We have fast tracked our hobby so muck in the short time I've been here by sharing good news and bad news . HOORRRRAAHH !
Wild Bill
Post by Wild Bill »
Yep, much gratitude to all that have gone before me and shared their experiences on this forum. It has certainly reshaped the learning curve and allowed many of us rookies to make a decent drop right out of the gate! :thumbup:
lil misfit
couldn't agree more with Tb or Wb the info is here if you spend the time to look for it. a true credit to the site and its members. quick thought toward holding the corks how about a simple bail like on the old style mason jars?
Wild Bill
Post by Wild Bill »
On the thumper Tee I do not use anything to hold the cork in and it seems to stay in fine. On the boiler side I used this SS 2”x1.5”x2” triclamp reducing tee. At the top of tee I install a 2” triclamp blank that I drilled and tapped for 1/4” npt and I threaded a 5 psi safety valve into it. It has worked great so far and is nice to be able to pull up on safety valve ring and vent piping at end of run or to shoot the thump.
https://www.norcalbrewingsolutions.com/ ... Piece.html" onclick="window.open(this.href);return false;" rel="nofollow
MichiganCornhusker
Wild Bill wrote:Yep, much gratitude to all that have gone before me and shared their experiences on this forum. It has certainly reshaped the learning curve and allowed many of us rookies to make a decent drop right out of the gate! :thumbup:
+1
I would have never come up with such a versitile, compact rig without all of the contributions here!
MichiganCornhusker
Wild Bill wrote:On the boiler side I used this SS 2”x1.5”x2” triclamp reducing tee. At the top of tee I install a 2” triclamp blank that I drilled and tapped for 1/4” npt and I threaded a 5 psi safety valve into it.
I like that idea and I might modify mine the same way.
After 3 years my 2” corks are starting to degrade.
I like the idea of replacing them with a triclamp plate and prv.
I could always make a 2” triclamp “shooter” contraption for the thumper if I wanted it for certain runs.
The real beauty of this thing is how modular it can be, and how easy it is to configure any which way.
Wild Bill
Post by Wild Bill »
Yes the modulatity is awesome for sure. Here is the relief valve I used. It will actually remain open if you lift up and cock plunger to the side slightly. Thanks again for the inspiration!
https://www.amazon.com/gp/aw/d/B01KO7NB ... SY340_QL65" onclick="window.open(this.href);return false;" rel="nofollow
BlackStrap
Just finished the water test for leaks and a vinegar run to cleanup flux...still need to do a sacrificial run & and make the outside shiny 8) but I'm happy with the results so far. on the vinegar run...Filled the steam keg (primary) with 10 gallons water/vinegar and mash keg (secondary) with 7 gallons water vinegar. Took an hour and 5 mins for steam out of the condenser... testing the flow rate, was able to pull 1 quart (.946 liters) at 5:30 minutes.
I am so thankful for this forum, and the great people here sharing ideas... :thumbup:
Left is the Steam Keg Middle is the Mash keg and the right is the reservoir... In the back ground is the control panel that also controls a 3 vessel brewing setup.
Another view showing 5lb pressure relieve valve with helps prevent suck back at the end of the strip run.
Ease of access on top of the mash keg there is also a drain on the bottom for cleaning.
Your going to love your steam rig
It's wonderful to be able to cook mash and distill, with ease :thumbup:
On a side note. Your big SS cooling water reservoir would make a great mash cooker
BlackStrap
Unfortunately the reservoir is aluminum, and was used as an used oil drum, :silent: but the price was right Free! :thumbup:
Not to hi-jack this thread...
but I do have a mash cooker set up with a modified drill press as a stirrer,
I use the big 20 gallon stainless pot with a heating element (on the top tier in background of the first picture my previous post)
filled with water the keg slides down inside and is held in by ratchet straps so it becomes a double boiler, no scorching :)
Here's what I come up with for mashing corn.
Bain Marie (double boiler) heated water jacketing the outside of the keg cooks the corn when cooled to 154 or so throw in malted barley for conversion :)
Another view
Another view
Copper stir paddle
Copper stir paddle
Copper stir paddle side view
raketemensch
Post by raketemensch »
Love the bearings on the “bit,” this is a really interesting design.
How well has your “blade” held up to the speed and pressure?
Post by The Baker »
Brutal wrote: Wed Mar 09, 2016 1:16 pm
Hillbilly Popstar wrote:So MCH, your build has me thinking...
What if the line arm between the boiler and the thumper had a built in shotgun condenser? Then when you run. You could charge the boiler with wash and run the shotgun, then after your thumper is charged up with low wines, you could switch the water flow off on the shotgun and switch it to a liebig coming off the thumper and use the steam from your backset to heat the low wines for a true double run without sacrificing any flavor.
Seems like it would be a VERY versatile setup. Could even run the shotgun at half throttle to get hot distillate and not have to work as hard to heat the low wines, and I was even thinking that if you dialed back the shotgun after the heads come over the strip, then switch to steam mode on the thumper, you might be able to get a slightly higher heads compression?
What you re describing will work, and I think the main advantage would be flavor. I also see how it would be hard to describe in text format. I haven't tried it but I will. Don't hold your breath waiting on me though. I haven't got a run in in a long time. I'd love to hear a side by side comparison of the product.
Does that sound a bit like running two stills, one after the other?
I think the whisky people (the traditional, single malt, not 'blended') do that.
It would have the big advantage that you would not have to warm the second run from dead cold. And the first 'still' would ideally be fairly big, but the second 'still' could be smaller.
Which is the usual set-up for a still plus thumper, the only extra piece of gear being a second product condenser (or worm), and provision to heat the second 'still'.
And if all your connections are modular you have the flexibility to make these arrangements.
