Steam generator test
Any steam Cooking /Distilling Device
Re: Steam generator test
Postby shadylane » Tue Jun 06, 2017 8:45 am
copperlover1 wrote:When the water solenoid functions it kills the steam because it let's it in directly to the tank. So I timed it. 25 seconds steam. Water solenoid cycles. Steam dies for about 5-8 seconds. Than full steam again
Maybe have an electric valve to vent the boiler, when the water valve is open
That might fix the problem caused by the "5-8 seconds" of vacuum
Postby Yummyrum » Wed Jun 07, 2017 1:48 am
copperlover1 wrote:Tastes like a lot of vinegar.
That's a big shame CL1 , :thumbdown:
Maybe some of the bath toys weren't clean . .....seriously though , You are a braver man than me fermenting with nothing to stop the critters and fly's getting in
Postby copperlover1 » Tue Jun 20, 2017 2:11 pm
That's just overflow from the air lock sitting on the lid.
copperlover1
Postby shadylane » Tue Jun 20, 2017 3:19 pm
That don't sound good :oops:
Real sour would sound better
Postby copperlover1 » Tue Jun 20, 2017 7:10 pm
I had to dump it all. What a mess. I loaded it all up in my Dr power wagon. Made it half way through the field. Hit a bump and.the dumper tripped and blam-o. I wish I had a video. Everything is on hold now. My youngest son is graduating high school so the focus is on his party. He will be leaving for marine boot camp early August.
copperlover1
Postby Yummyrum » Wed Jun 21, 2017 12:36 am
copperlover1 wrote:That's just overflow from the air lock sitting on the lid.
Yes I see now :oops: ...what a mess .
Postby copperlover1 » Thu Jul 27, 2017 3:20 am
Ok everyone I finally got the check valve. Where is the best location for it?
copperlover1
Postby Brutal » Sat Sep 30, 2017 10:59 am
Hey CL did ya cook anything with it yet?
Brutal
Postby copperlover1 » Tue May 15, 2018 2:06 pm
Nobody wants to help me locate the check valve?
copperlover1
Postby copperlover1 » Wed May 16, 2018 4:40 am
Going to start with it at the bottom.
copperlover1
Postby copperlover1 » Thu May 17, 2018 5:18 pm
Ball valve to control the water in. Hopefully I can keep the boil when the solenoid valve let's in water. Planning a test run Saturday.
copperlover1
Postby StillerBoy » Thu May 17, 2018 5:32 pm
Thanks for the update..
Mars
StillerBoy
Postby acfixer69 » Thu May 17, 2018 6:01 pm
copperlover1 wrote:Ball valve to control the water in. Hopefully I can keep the boil when the solenoid valve let's in water. Planning a test run Saturday.
regulating make up water is never a good idea IMHO.
acfixer69
Postby Yummyrum » Thu May 17, 2018 7:03 pm
Copper , the check valve will stop the mash sucking back for sure ..... but if a vacuum is being created , you need to let something in or your boiler may implode . Do you have a second check valve to prevent this ?
And by the way , hope you have better luck this run
Postby copperlover1 » Fri May 18, 2018 2:46 am
I have a vacuum pressure gauge and a breaker Valve on the top of the steam wand.
I don't want to buy a regulator just to test my theroy of controlling the in water to maintain the boil. If it works I will buy one so no one can accidentally close the supply off.
copperlover1
Postby copperlover1 » Fri May 18, 2018 2:48 am
Great questions guys. Made me put out answer's I have in my head but forget to put on paper so others can see them.
copperlover1
Postby copperlover1 » Sat May 19, 2018 2:57 pm
Success. I think the check valve would be enough but I ordered a water regulator valve to replace the ball valve. I have unlimited hot water at home so I was able to start with 100°f water. 100 lbs of corn ground to corn meal. Took it to 190°f in 1-1/2 hours.
copperlover1
Postby acfixer69 » Sat May 19, 2018 3:09 pm
That is awesome. Regulating valve will make it even better to dial in the feed rate. Nice job :thumbup:
acfixer69
Postby copperlover1 » Sat May 19, 2018 5:27 pm
Thanks. I should have a sg in the morning. The mash is really grain heavy but I wanted to see how it went with maximum weight on the steam wand.
copperlover1
Postby shadylane » Sat May 19, 2018 6:00 pm
:thumbup: looking good, Ya got 100# of corn cooked :clap:
Tell us more about your process
Postby copperlover1 » Sun May 20, 2018 5:45 am
SG this morning was 1.073 potential 11.99 %. I bit high so I will scoop some out into another drum and water it down.
copperlover1
Postby MichiganCornhusker » Sun May 20, 2018 6:11 am
No stir, no muscle, no scorch. Very nice. :thumbup:
MichiganCornhusker
Postby copperlover1 » Mon May 21, 2018 5:01 pm
Yes steam is the way to cook grains. Now I need to work on building a thumper.
My process for this batch was very basic. I barely follow and real protocol.
It's a 40 gallon food grade barrel. So I filled it half way with hot tap water. Put my SEBstar HTL in. Which I calculated wrong. I did it for 50 lbs. And than I turned on the steam. I adjusted the ball valve so the water in would only slow the boil down. It was like a 1-2 second pause. But with the check valve it always had pressure in the line.
I started adding my 100 lbs of corn. That's my enzyme calculation mistake. Got the paddle mixer in there and mixed it all up.
The pressure gauge held at 3 PSI the whole time. And it took 1-1/2 hours to get to 190°.
I shut it down and opened the bypass valve to vent the system. Pulled the steam wand out and covered the barrel. I made sure I cleaned it good and flushed the check valve good.
I left it 2 hours. Added cold water to get to 150° and added the SENamyl. Again I used the wrong amount. I figured 50 lbs. Than I left it until the morning.
The SG was 1.073 which was a bit much so I took some out and watered them down. Pitched my bread yeast and she was bubbling in 30 minutes.
So I only used half the amount of enzymes I was supposed to use and it still did great. You can't go wrong with them.
copperlover1
Postby hellbilly007 » Wed May 23, 2018 3:33 pm
I'm glad to see that worked out for ya copperlover. This gives me something to keep an eye out for.
hellbilly007
Postby copperlover1 » Thu May 24, 2018 8:18 am
Regulator came in. I have I set up for garden hose fittings.
copperlover1
Postby copperlover1 » Sat Jun 02, 2018 3:07 pm
Regulator in place. RV water hose . Gauge says about 8 psi. The boil stops but only for a second or two. Ran it today. Three batches. 75 lbs corn and 30 gallons water each batch. 2 hours to get to 190° F. It was a beautiful thing to watch.
copperlover1
Postby copperlover1 » Sat Jun 02, 2018 3:09 pm
In action
copperlover1
Postby shadylane » Sat Jun 02, 2018 3:56 pm
I'm jealous
Your steam cooker is prettier than mine
Postby WIski » Sat Jun 02, 2018 6:35 pm
Copper, any idea how much water you added to the mash while cooking for the 2 hours?
WIski
Postby copperlover1 » Sun Jun 03, 2018 4:56 am
Sandylane don't be jealous of me. It's not mine anymore. It's was actually a experimental build for a friend who started a small distillery. When I started the post he wasn't licensed. That was part of the very long pause in the post. Waiting for him. He has a small working space and a very limited budget.
Wiski: I'm not exactly sure how much water. I tried to watch it rise and measure the barrel. Less than five and more than two. Next time I will mark the barrel. Than scoop out when I'm done to take down to the mark. I'll post exactly how much.
copperlover1
PreviousNext
Return to Steam Mashing and Distilling
Who is online
