Steam bourbon
Any steam Cooking /Distilling Device
Re: Steam bourbon
Postby RedwoodHillBilly » Wed Nov 18, 2015 5:48 pm
shadylane wrote:Figure to give this batch to my only teetotaler sister for long term storage.
Must be nice. I wish I had a teetotaler to do storage for me. :)
John Barleycorn must die.
"and little Sir John in the nut brown bowl proved the strongest man at last.
The huntsman he can't hunt the fox, nor so loudly to blow his horn
and the tinker he can't mend kettle nor pots without a little barleycorn."
RedwoodHillBilly
Re: Steam bourbon
Postby shadylane » Wed Nov 18, 2015 6:04 pm
My other sisters drink, and the teetotaler sister likes them better than me. Pilferage is to be expected.
Hopefully there will be enough left to see how it tastes after proper aging.
Re: Steam bourbon
Postby skow69 » Wed Nov 18, 2015 6:10 pm
Har! That reminds of the guy on the other end of that spectrum who couldn't get his friends to stop drinking his feints.
Good work, shady! Enjoy.
skow69
Re: Steam bourbon
Postby shadylane » Sun Mar 13, 2016 3:18 pm
Just an update.
The steam bourdon is aging very well.
Sadly, it's not going to last much longer. :lol:
And I've changed my equipment and protocol.
Re: Steam bourbon
Postby Antler24 » Fri Jan 12, 2018 8:13 am
Steam injecting a 15g mash in this method, is there any need for the pressure relief valve? I've got the extra copper kicking around to build the steam wand and was thinking about trying it out soon. I wouldn't have thought it be any different than running the still with solids in the thumper.
Swedish Pride wrote:
Antler24
Re: Steam bourbon
Postby RedwoodHillBilly » Fri Jan 12, 2018 8:18 am
Antler24 wrote:Steam injecting a 15g mash in this method, is there any need for the pressure relief valve? I've got the extra copper kicking around to build the steam wand and was thinking about trying it out soon.
In theory, no. In practice, it can't hurt to be paranoid. You're not paranoid if they are really out to get you. :)
I run a PRV on my boiler when I steam strip in my thumper.
RedwoodHillBilly
Re: Steam bourbon
Postby shadylane » Fri Jan 12, 2018 11:46 am
A manometer is cheap, reliable and simple to build.
The one on my steam rig is 2 meters tall
Re: Steam bourbon
Postby Soft batch » Sat Jan 13, 2018 8:45 am
"I stumbled upon this while looking for something else" to quote Shadylane. I recently completed my steamer build nearly identical setup complete with a 15 gallon BOP for the corn. I'm using my copper pot instead of a keg for the boiler and have a braided SS covered pipe for the steam injector. Currently I have a 1/2" pipe extended with a cork in it for a PRV.
A couple of questions.
1) What size pipe/tubing do you use for the manometer?
2) how hot does it get - can I use vinyl tubing for the "visible" section?
3) Do you use filtered water in the boiler to eliminate sediment buildup?
Soft batch
Re: Steam bourbon
Postby The Baker » Sat Jan 13, 2018 3:50 pm
"braided SS covered pipe"
That doesn't have a rubber/ plastic lining, does it?
Re: Steam bourbon
Postby Soft batch » Sat Jan 13, 2018 4:05 pm
The Baker wrote:"braided SS covered pipe"
No - rubber tube removed and a copper pipe with slits inserted. See Brutal's steam injection attachment viewtopic.php?f=92&t=52926
Soft batch
Previous
Return to Steam Mashing and Distilling
Who is online
