rgreen2002 wrote:Welcome to the steam club Hank(this welcome is of course from a guy dead in the middle of his first steam mash and ferment). That's a nice start you have there...it could probably run forever. John Galt would be proud.
rgreen2002 wrote:Hank, how are you planning on holes for the head piece? Corn has a predilection for getting everywhere you don't want it to be.
shadylane wrote:Looking good hank![]()
Have you considered using a TALL Manometer to measure the boiler pressure.
That way you will be aware of over pressure before the 15psi PRV vents.
The Manometer could be a super accurate and reliable PRV that uses water and gravity
Hank Reardon wrote:I will spend some time googling tall manometers.
Hank Reardon wrote:Finally got to the cleaning run yesterday. She performed like a champ. A noisy little champion.
Brought 5 gallons of water in the BOP to a boil in around 40 minutes.
I'm thinking the 1st Booner's will be mashed over Labor Day. Before then, I still have to clean the outside of the piping, and the go to town.
I will try to post a video when corn is in the pot.
shadylane wrote:Don't forget the earplugs
Hank Reardon wrote:rgreen2002 wrote:Hank, how are you planning on holes for the head piece? Corn has a predilection for getting everywhere you don't want it to be.
I was thinking about drilling holes parallel to the floor, but I see MCH did his face down. I'm thinking face down sounds good to me.
Hank Reardon wrote:... The PRV is 15#, ...
steelmb wrote:Hank Reardon wrote:... The PRV is 15#, ...
Do you have any specs on that pot regarding pressure? 15 psi is a fair bit of pressure for a vessel that size. I really doubt you will ever get to 5 psi let alone 15 psi unless something really goes wrong but that is what a PRV is for. However the PRV will do you no good if it is sized incorrectly and something on your boiler lets loose before reaching the pressure that the PRV is rated for.
Tomb wrote:Hope this is not too OT...
How much water would it take to generate the steam to boil 5 gallons in the pot?
Would that steam increase the volume in the pot?
T
Hank Reardon wrote:...and no matter what, it will have some relation to UJ. .
Return to Steam Mashing and Distilling
