Steam generator test
Any steam Cooking /Distilling Device
Postby copperlover1 » Sat May 20, 2017 3:01 am
I have read about people asking if a steam generator for a sauna would work to mash with. I haven't seen anyone test one yet. So I convinced my wife that if it doesn't work I would put it in our shower to add steam to it. So I picked up a 7kw for $150. 220-240 volt. The manual says 31.8 amps. Time for a few pics.
copperlover1
Re: Steam generator test
Postby copperlover1 » Sat May 20, 2017 3:14 am
Inside
copperlover1
Postby copperlover1 » Sat May 20, 2017 3:32 am
Backside tag
copperlover1
Postby shadylane » Sat May 20, 2017 3:44 am
You have my attention :thumbup:
Postby yakattack » Sat May 20, 2017 3:47 am
Subbed. Can't wait for the results
yakattack
Postby copperlover1 » Sat May 20, 2017 3:49 am
The generator has a prv valve so I just have a valve and vacuum/pressure gauge on top of my magic steam wand.
copperlover1
Postby rgreen2002 » Sat May 20, 2017 12:25 pm
Hmmm....go on.... :mrgreen:
HD Glossary - Open this
rgreen2002
Postby DBCFlash » Sat May 20, 2017 2:18 pm
I'm following this one.
Some men you jest cain't reach...
DBCFlash
Postby mrjames680 » Sat May 20, 2017 2:40 pm
Wow I was just thinking about this yesterday and was doing some research so I could post a question about it.
Sent from my SM-N900V using Tapatalk
Don't sweat the petty stuff and dont pet the sweaty stuff
mrjames680
Postby Truckinbutch » Sat May 20, 2017 4:35 pm
DBCFlash wrote:I'm following this one.
Bofus :thumbup:
Truckinbutch
Postby Yummyrum » Sat May 20, 2017 4:56 pm
Thats an impressive piece of kit for $150 ...: hope it works
Postby shadylane » Sat May 20, 2017 6:01 pm
I've noticed the stock controller is rated for 35°C~55°C
But that shouldn't be too difficult ta hack.
https://xsauna.en.alibaba.com/product/9 ... _7_KW.html
Postby RedwoodHillBilly » Sat May 20, 2017 7:18 pm
shadylane wrote:I've noticed the stock controller is rated for 35°C~55°C
Looking at some reviews on Amazon, I believe that the 35°C - 55°C is the setpoint for the sauna based on a remote temp sensor. If so, no controller hacking would be required, just leave the sensor in free air. I will be watching to see how this works out. They make a number of versions, I wonder if the only difference is the heating element and perhaps an over current adjustment.
John Barleycorn must die.
"and little Sir John in the nut brown bowl proved the strongest man at last.
The huntsman he can't hunt the fox, nor so loudly to blow his horn
and the tinker he can't mend kettle nor pots without a little barleycorn."
RedwoodHillBilly
Postby copperlover1 » Sun May 21, 2017 9:50 am
Magic steam wand in the barrel. Everything is 3/4". And ss flex line with the inner rubber hose removed. The head is pinned on so is can easily be removed for cleaning.
copperlover1
Postby Truckinbutch » Sun May 21, 2017 10:08 am
Impressive :thumbup: I went the alternate route with a speed controlled paddle mixer in a BOP because I could . That looks to be a promising alternative for folks with more limited resources .
Truckinbutch
Postby shadylane » Sun May 21, 2017 12:46 pm
copperlover1 wrote:The head is pinned on so is can easily be removed for cleaning.
Excellent idea :thumbup:
Postby acfixer69 » Sun May 21, 2017 5:46 pm
Truckinbutch wrote:Impressive :thumbup: I went the alternate route with a speed controlled paddle mixer in a BOP because I could . That looks to be a promising alternative for folks with more limited resources .
Do you have a thread on that mixer butch. I haven't found it but am struggling on a mixer now. Don't want to take this off topic.
I did try a steam cleaner to heat a 5 gal of water to look at a nozzle design to induce a flow that would not need a paddle but the velocity was not there.
AC
acfixer69
Postby Truckinbutch » Sun May 21, 2017 6:29 pm
I'll PM you to not jack the thread . Decent of you to not go off topic .
Truckinbutch
Postby WIski » Mon May 22, 2017 4:34 am
TB Wrote,
Please share with all. Sounds very interesting. We will be looking fro new thread. :thumbup:
WIski
Postby copperlover1 » Mon May 22, 2017 8:13 am
The controls are quite simple. I don't think I will have to do more than just hand the probe in the air. It times out after 60 minutes. But I don't like to leave anything unattended so that shouldn't be an issue either.
copperlover1
Postby copperlover1 » Tue May 23, 2017 3:31 am
Closer look at my steam wand pin.
copperlover1
Postby copperlover1 » Tue May 23, 2017 3:32 am
I also scored 12" of 12/4 wire. Now to fine a panel clamp to hold it in place.
copperlover1
Postby copperlover1 » Tue May 23, 2017 8:13 am
I looks up my wire it's only good to 20amps. I need to find some 10 or 8 gauge.
copperlover1
Postby rgreen2002 » Tue May 23, 2017 10:51 am
copperlover1 wrote:Closer look at my steam wand pin.
She is looking good copper... A side note. I have been steam mashing for about a year and I noticed that those hose clamps (even the SS ones) get real ugly after a while. Just keep an eye on them. I ended up getting a few copper plated clamps and use a very similar wand setup.
viewtopic.php?p=7420026#p7420026
rgreen2002
Postby copperlover1 » Sat May 27, 2017 5:33 am
Help. I can't for the life of me figure out where to put my wires.nit sure if you will be able to read it.
copperlover1
Postby still_stirrin » Sat May 27, 2017 10:28 am
The ST-70 is a single phase 220/240 VAC unit, so you'd use the connection diagram on the right with 2 hot lines and a neutral (plus the ground, of course).
For your hook up cable, typically the white wire is the neutral and the 2 hot leads are red and black (or some other color, ie - yellow, blue, etc.). "Green is the ground the whole world around".
So, you'd connect +V1 (red) to L1 and +V2 (black) to L2. And you'd connect N1 (white) to N1 and ground (green) to the ground buss. At least that's the way I interpret the schematic. If in doubt, get a certified electrician to make the hook up for you. You're dealing with enough power to do damage, so be careful.
What is a Proof & Traille hydrometer: Alcohol-meter
Enzyme info: SebStar
HD Google search info: HD Google-how to
All about mashing grains: Braukaiser
Master Distiller
Postby RedwoodHillBilly » Sat May 27, 2017 10:34 am
still_stirrin wrote:The ST-70 is a single phase 220/240 VAC unit, so you'd use the connection diagram on the right with 2 hot lines and a neutral (plus the ground, of course).
You sure? The way I read it is that L1 would connect to the 2 L terminals (schematics shows jumpers installed between the 2 L terminals and between the 2 N terminals) and L2 would connect to the 2 jumpered N terminals. GND (PE) connected to GND.
I don't think that it uses neutral.
edit:
I think that the reason that for 220V it is labeled L and N is that in a 380 3phase system you get 220V line to neutral.
RedwoodHillBilly
Postby still_stirrin » Sat May 27, 2017 10:59 am
No, I'm not sure.
It is a bit confusing according to the text:
"...machine's three-core cable (220V) (two power wires and one earth wire)....Connect earth wire and the yellow and green core wires. Connect the two power cords with the connection port making "L", "L", "N", and "N" separately...".
I see where the 220/240 line voltage would be input between the "L" and "N" terminals if connected with the two hots on those respective terminals. And the Neutral/Ground connected to the GND terminal, as is typical with a 220V 3-wire system.
Master Distiller
Postby RedwoodHillBilly » Sat May 27, 2017 12:42 pm
still_stirrin wrote:No, I'm not sure.
Fixed that for you. Neutral and ground are 2 separate things everywhere except in the main load center (panel).
RedwoodHillBilly
Postby shadylane » Sat May 27, 2017 12:52 pm
I might be wrong, but if I was wiring it.
I'd connect the ground
I'd connect a jumper from L3 to L2 and connect a 220V hot wire to it
Then Jumper L1 to N and connect the other 220v hot wire to it
There won't be a neutral
Next
Return to Steam Mashing and Distilling
Who is online
