Distilling Tumeric Leaf
All things related to oils and Hydrosols. How to make them and their uses.
Postby Ashtree » Mon Feb 25, 2019 7:53 pm
Does any one have experience distilling Tumeric leaf?
I just got hold of a fresh sack about 8-10 kilos and am looking to distill it ASAP. Not sure of the yield % or if if its bets dried first, or soaked in hot water?
Most sources only mention Tumeric root oil. My still is a 70L copper alembic from Portugal.
Ashtree
Re: Distilling Tumeric Leaf
Postby still_stirrin » Mon Feb 25, 2019 8:08 pm
I found this: https://www.youtube.com/watch?v=myorenp ... ture=share
Maybe that will help you. A worldwide web search is your friend.
What is a Proof & Traille hydrometer: Alcohol-meter
Enzyme info: SebStar
HD Google search info: HD Google-how to
All about mashing grains: Braukaiser
Master Distiller
Postby Ashtree » Mon Feb 25, 2019 8:29 pm
No, thats tumeric root and its not a distillation.
Ashtree
Postby Saltbush Bill » Mon Feb 25, 2019 9:13 pm
I grow Turmeric in my garden , Ive only ever used the roots ? I know that in some Asian countries that the leaves are also used in cooking.
What is it that you hope to distill from the leaves ? and what is it used for ?
Postby OtisT » Tue Feb 26, 2019 1:15 am
I did a little googling on “turmeric leaf distillation” and found one description of “steam distilling” the leaf. The root is steam distilled also based on what I found.
I don’t know for sure what “steam distilling” is. Likely water, but I could not rule out ethanol vapor.
Otis
OtisT
Postby Ashtree » Tue Feb 26, 2019 7:13 am
Saltbush Bill wrote:I grow Turmeric in my garden , Ive only ever used the roots ? I know that in some Asian countries that the leaves are also used in cooking.
Yes the leaves contain plenty of aroma and oil also. Steam distillation is your typical distillation for essential oils, when you pass steam through organic material.
Ashtree
Postby JellybeanCorncob » Tue Feb 26, 2019 3:47 pm
Hey Ashtree:
Like SS said the Internet is your friend for information.
Ive never extracted turmeric E-oil because have no access to large amounts of turmeric leaves or rhizomes. But my friend the internet says: “The yield of turmeric oil obtained from leaves ranges between 2.75-2.83% and from rhizomes ranges between 2.38-2.48.” Read some of Bushman’s posts on steam distillation. It will help educate you on theory and how too. I have a couple of posts in the essential oil’s Section that have picks of my old boiler and my new stainless steel one. Just remember that like making gin, the boiler, column and libeg are now coated with residue from the oils you have extracted. So you probably should reclean your rig before using it to make alcohol.
Here’s a hint: Google “simple distillation of essential oil’s”
That will get you going.
Good luck
JBC
JellybeanCorncob
Postby JellybeanCorncob » Tue Feb 26, 2019 3:55 pm
JellybeanCorncob
Postby Ashtree » Fri Mar 01, 2019 9:37 pm
Hi jellybean, cheers for that.
Yeh i wouldnt mix alcohol or essential oil distilling together either, i have seperate distillers. Not worth it.
Well i just spent the last 2 days distilling Tumeric leaf, processed about 8 kilos of fresh leaf. Im not getting anywhere near 2.7%
Thats 27ml per kilo right?
Ashtree
Postby JellybeanCorncob » Sat Mar 02, 2019 8:44 am
Ashtree wrote:Hi jellybean, cheers for that.
Physics isn’t one of my strengths. And after trying to use the calculations that are easily found on the web I realized that there are too many variables and unknowns to get a accurate answer for % yealds. I gave up trying and use the percent yield guides for an estimate of what to expect. https://www.essentialoil.com/pages/percentage-yield
Depending on when you harvest, type of plant and extraction methods the the % of essential oils may be different. For me I’ve found that if I turn the temp down and distill at a slower rate and crush or shred my plant material my yield is larger.
I hope this helps
JBC
JellybeanCorncob
Return to Essential Oils
Who is online
