Good additions
- Site Admin
- Single Malt Yinzer
Re: Good additions
Thanks. Good job with the macerate un-duplication. That kind of clean up is a pain but makes entries so much better. Liquor/cordials needs that. Is there a way to easily rename entries? Because http://homedistiller.org/wiki/index.php/index.php ... d_Liqueurs" onclick="window.open(this.href);return false;" rel="nofollow probably should be [[Cordial and Liqueur Recipes]]. If not I can just rename it via copy/paste sometime.
- Site Admin
Re: Good additions
Yep up on top of any page is an entry for "More" and under that is "move". Allows you to decide if you want to leave a redirect in place or not.Single Malt Yinzer wrote:Thanks. Good job with the macerate un-duplication. That kind of clean up is a pain but makes entries so much better. Liquor/cordials needs that. Is there a way to easily rename entries? Because http://homedistiller.org/wiki/index.php/index.php ... d_Liqueurs" onclick="window.open(this.href);return false;" rel="nofollow probably should be [[Cordial and Liqueur Recipes]]. If not I can just rename it via copy/paste sometime.
- Site Admin
Re: Good additions
I see that.Single Malt Yinzer wrote:Thanks. Good job with the macerate un-duplication. That kind of clean up is a pain but makes entries so much better. Liquor/cordials needs that. Is there a way to easily rename entries? Because http://homedistiller.org/wiki/index.php/index.php ... d_Liqueurs" onclick="window.open(this.href);return false;" rel="nofollow probably should be [[Cordial and Liqueur Recipes]]. If not I can just rename it via copy/paste sometime.
Just merged [[cordials]] and [[cordial]] into [[cordial]]. Changing links on the main page showed that [[cordials and liqueurs]] was linked. I split that into [[cordial]]s and [[liqueur]]s. The [[cordials and liqueurs]] is a recipe page and needs to be treated as such.
Re: Good additions
Awesome, thank you sir!
