Missing info?
- Site Admin
Missing info?
Just wondering if we should start adding info on how to actually make stills, electric controllers, soldering etc?
Re: Missing info?
Well Jess, They would need to be vetted, especially electrical work. I screw up a soldier joint, I can clean it up and try again. I screw up an electric connection, no telling what could happen. Voltage on a ground, A not so “neutral” voltage to ground.
Everyone should know NOT “everything on the internet”. Is true! But.
Honestly, much of the information here is how to do this. You need to be swift enough to put the final pieces together.
Bear in mind I do risk management all day. My mind always asks, “We’ll, how can this be screwed up?”
Great site, Thanks.
Great site, Thanks.
Re: Missing info?
When Mulekicker was active he was making and selling controllers he also wrote a tutorial for making your own controller.
viewtopic.php?f=85&t=14076&p=6842395&hi ... w#p6842395
Re: Missing info?
I think it would be great if there was a consolidated, "tried n true" section on construction of various still types. Many examples here and elsewhere but no real "I made that, it works" vetting. I have used input to do some controller work, too. It ain't rocket science. Good schematics and pictures abound. Maybe it would be good, real good, to proof 'em out and publish what works. Here again, if you can't follow pictures and simple instructions maybe you shouldn't be there an doin' that. It's best, IMHO to give people clear guidance rather than let unlimited experimentation "in the dark" clear the gene pool.
- Single Malt Yinzer
Re: Missing info?
Still: Yes. If we can find someone that can CAD or draw diagrams for parts & stuff I can make Wiki entries for them.
Electrical controllers: Yes. Again - if we can decide on two (one for 120v and one for single phase 220) we can wikify them.
Soldering: I can find a bunch of youtube stuff on that. Not sure we need to do much effort on this one. I would say we should make sure people understand materials need to be food safe, aside from that there isn't much I think we can add of value.
- Site Admin
Re: Missing info?
Well, I suppose the soldering info I would consider is bonding copper to stainless steel. I've seen some good threads with tips on this and I don't think it's really a common thing like soldering electrical connections or sweating copper.Single Malt Yinzer wrote:Still: Yes. If we can find someone that can CAD or draw diagrams for parts & stuff I can make Wiki entries for them.
Re: Missing info?
I can see there a lot of still building info on here already. Basic guidelines for say column diameter vs pot size or thumper size vs pot size and the like might not be a bad idea. My be just a sticky with the basics. Funny you mentioned the copper to stainless solder trick. I was thinking about that myself tonight. Controllers are fun to build I think, but I am kinda handy with that stuff. I built a nice little pid controller to start out with and it works great. A forum for that might be a good idea.
