Archee72 wrote: ↑Tue Dec 22, 2020 1:38 pm
NZChris wrote: ↑Mon Dec 21, 2020 10:18 pm
Congratulations Archee.
I've used several different citrus, including mandarin from from our own tree, and mandarin is very good, and like you, my only tailsy gin was my fault. It sounds like you are well on the way on your gin journey.
Thanks Chris, had a bit of trouble sourcing juniper berries locally for my latest batch so half the amount in my current maceration, will share how it comes out.
Archee, you might try Scoop Wholefoods. We have a shop in Bondi. I get my juniper berries from there. A few bucks worth is enough for a 7.0L maceration. I believe they're in Queensland so if there's one near you...
And in passing, I'm catching up on this thread so a few random points:
1. I'm using Sydney tap water to dilute the gin. I tried some Coles Spring Water a couple of runs ago and I'll be honest - I can't tell the difference.
2. My citrus bill is up to about 18g per litre - I've tried a variety of oranges, grapefruit, tangelos, mandarins and lemons (no pith). And my juniper is up to around 15g.
3. The last run (version VIII) I threw in a julliened Thai lime leaf and 4 cardomon pods - but I used the green ones as opposed to the black. Sitting in a demijohn for another two weeks before sampling.
4. I take the first 10 ml then have just started to take the next 10 in another jar to test for louching. Maybe the amount of citrus I'm using carries more oil over. I spend enough time making crystal clear ice so I get paranoid about getting a cloudy gin.
5. I collect about 420ml per litre (I macerate 7.0L and collect 3.0L). That gives me 5.0L plus of very good gin.
6. I've been saving a bottle of each version from version 2 onwards (going back about 8 months) so maybe this weekend I'll do a sample of each to see how a few months affects the flavours.
