Nice work! For what it's worth, I think you should try a sample once a week over the 5 weeks so you get to experience how it changes over time.
Or do what I do and make at least two bottles at a time. Hide one.
TwoSheds
+1 (or 3 )
Hey Coogee! Just wondering how much cardamom and lime you added. Was thinking of doing something similar
Make more, as soon as you can, then more! Not that you need a ton of it, but with a few batches on hand you'll end up having some of it age. It does get better! I don't think it's flavors 'marrying' as much as some of the more volatile and less desirable flavors dissipating and leaving behind the good stuff.
500ml seems to be pushing further in, that's 25% over 400ml so a big addition.
Read the whole quote: viewtopic.php?p=7358836#p7358836
Thanks NZ, I'll take your advice then, I just thought that I may have been able to push further in seen as the neutral had already had the cuts done prior.
There isn't a need if you are happy to make OEG.
It looks like what I would expect from a very greedy OEG.
Yep, the cloudy jar was from my 2nd ever trial run of flavoured product, macerated at 62% - 24hrs (it was not todays run).Saltbush Bill wrote: ↑Thu Jan 26, 2023 10:48 am That's one of the last jars of the run I'm guessing.
Well to me it tastes ok at best, I had split a bottle off the jar which is nearly gone and as I looked at the jar today, I got worried.
I macerated at 62% but reduced to 43% for distillation, I was trying to be clever and shorten the 2 week maceration time. Yes I understand that it will extract unequally over the various ingredients. I need to take a step back I think. It was my rushed way to test a product asap.still_stirrin wrote: ↑Thu Jan 26, 2023 1:00 pm Also, you macerated at 62%ABV, which is higher than what Odin prescribed. Doing that will dramatically affect the rate of extraction of the juniper oils as well as the flavor contributions from the botanicals, especially the citrus.
This is OK if your goal is a really BOLD gin. And collecting your spirit off of the still will have a higher %ABV as well.
When tempered to 43%ABV as you said you did, it is not surprising at all that the louche would “jump out and bite you”. But, you probably got a big flavor from it though.
Noted and ordered thank you, so even a few seconds is a no no it seems?still_stirrin wrote: ↑Thu Jan 26, 2023 2:14 pm Uh oh Hebden. Your graduated cylinder is plastic. And I assume that’s what you use to measure your spirits in. Get a glass (pyrex) cylinder…you’ll be glad you did.
No its not recommended in this recipe Chris, but have you ever considered that in the case of Gin it could be the ethanol evaporating off and the Juniper oils and other flavors could be staying in the jars? If that was the case then Id suggest that the flavors might intensify.
Most of my gins are so high in VOCs that they louche at 45% unless they have neutral added to tame them so, if your theory was correct, it wouldn't be helpful to me, or to any of the many gin newbies who have come here asking for help because their gin has gone cloudy.Saltbush Bill wrote: ↑Fri Feb 03, 2023 12:26 amNo its not recommended in this recipe Chris, but have you ever considered that in the case of Gin it could be the ethanol evaporating off and the Juniper oils and other flavors could be staying in the jars? If that was the case then Id suggest that the flavors might intensify.
I think I already know the answer, I' ll let you have a play with the idea to find out.
I feel sorry for the angels at your place , they cant get much joy out of life.
COTM
Agree this is a very good process. Simple and easy. The citrus tames back over the next few weeks (if you stay out of it long enough. I have found some other unusual flavors early that disappear over the aging period as well so the “bubble gum” may go away over time or that may just be how you experience it (juicy fruit?).BrewinBrian44 wrote: ↑Sun Mar 05, 2023 11:23 am
I just proofed it down to 45% ABV. Of course, I can’t help myself, I’m gonna drink some. Wow! Very good right off the bat. I’m noticing a lot more citrus than juniper, but from everything I read it’ll appear more with some aging time.
An interesting thing I’m noticing, there’s a distinct bubble gum flavor in the spirit. It’s not bad though! Unique.
