Electric boiler agitator
Re: Electric boiler agitator
Man that looks sweet shady. I know I got one of those not ready for the junk box but can't remember last time I used it so I won't miss it. Really nice job
I figure gear reduction would help the air motor work better
But first, I need to make sure the seals work
Among other things this thread clearly shows: never throw anything away! Keep it somewhere where you can find it again.
I've got the "never throw anything away" coveredKareltje wrote:never throw anything away! Keep it somewhere where you can find it again.
The finding it again requires lots of time
ROFL.
Once I had a landlord with the same problem. He needed some thing, he knew where it was, even: in the back of a fully stuffed garage. So he decided to buy it again.
You found some things again, didn't you. Unexpectedly, but all the more making you happy.
Throwing out a jiffy mixer
http://jiffymixer.com" onclick="window.open(this.href);return false;" rel="nofollow
304 Stainless mixer. Lots of different sizes. Excellent build quality.
After making a run with the agitator. Here's something I didn't think about.
Agitating the wash, allows more power to be used before the boiler foams up and pukes
Can water be used to spin an air-motor
you're a legend Shady
got any close ups on how you coupled that rattle gun to the shaft .That would be my undoing .
hows the noise when its running ...guessing it might mask a thumper .
I like your water thinking . ....could make it a whole lot quieter .
What about steam
What about steam
Just run the output from your boiler through it before the condenser.Yummyrum wrote:you're a legend Shady
What about steam
I believe MCH may have said it best. "It's your hooch, you get to choose."
Ding Dong
http://w.homedistiller.org/forum/viewto ... =7&t=66849
Ding Dong
The "rattle gun" was already drilled and taped.Yummyrum wrote:got any close ups on how you coupled that rattle gun to the shaft
I drilled a 1/4" hole for the shaft it stick in
Bustedshadylane wrote:Can water be used to spin an air-motor
Don't know about all air-motors, but this one didn't run worth a damn on water
I think the speed control valve doesn't let enought water flow
Another problem, it would leak water all over the boiler
Hell I though you were joking. Air tools need oiling after each use because of moisture in the compressed air. That's why they have air driers in the lines after the compressor. Speed of air cfm to water cfm is not going to happen.shadylane wrote:Can water be used to spin an air-motor
Not only that the fluid(air or water) being used needs to expand as the motor rotates. Water will not work for this reason. Steam would work but is a very bad choice with no real gain and lots of drawbacks to using it.acfixer69 wrote:Hell I though you were joking. Air tools need oiling after each use because of moisture in the compressed air. That's why they have air driers in the lines after the compressor. Speed of air cfm to water cfm is not going to happen.shadylane wrote:Can water be used to spin an air-motor
Ding Dong
Ding Dong
Now Ya tell meacfixer69 wrote:Hell I though you were joking.shadylane wrote:Can water be used to spin an air-motor
Here's another hair-brained idea
Use a brushless DC motor to spin the agitator
Some thing similar to this
https://www.amazon.com/Hobbypower-1000k ... B99CTMKJ1Z" onclick="window.open(this.href);return false;" rel="nofollow
Ah, now I see. You want to prevent sparks near a flammable fluid/gas.
I forgot what it is called, but there is a construction like the cage of Faraday that works to contain flames. It was used in coalmines around the lights and the grind on Bunsen-buirners serves the same purpose.
(Sorry: it is late for me and I used my product.)
Am I missing some thing here? why do you want a DC motor to begin with?
wouldn't an AC motor with a cheap speed controller be a safer and more
controllable set-up? or a totally enclosed DC motor, brushless or not?
edit addition: Sorry shady loggged on to say the D.A. motor conversion was way cool
got lost after that but repurposing junk for re-use is my drug of choice
Way to go
bronctoad
Way to go
bronctoad
I'm playing around with different options for a DIY agitator
The professional agitators use expensive AC gearmotors and a VFD for speed control
Enclosed brushed motors have a problem with Ozone attacking the insulation
Air motors a LOUD and inefficent, next on the list of possiblities are stepper motors and brushless DC
I figured if I'd ever build an agitator I'd use one of these https://www.amazon.com/Stepper-Motor-26 ... ref=plSrch" onclick="window.open(this.href);return false;" rel="nofollow. That should be plenty of torque to move through the thickest of muck.
That's what I'm thinking alsohellbilly007 wrote:I figured if I'd ever build an agitator I'd use one of these https://www.amazon.com/Stepper-Motor-26 ... ref=plSrch" onclick="window.open(this.href);return false;" rel="nofollow. That should be plenty of torque to move through the thickest of muck.
The down side of a stepper motor, is it needs a controller and the controller needs a DC supply
It reminds me of some of the punk rock bands I've heard.Yummyrum wrote:hows the noise when its running ...guessing it might mask a thumper
The motor shrieks, the seal squeaks and the prop-shaft rattles.
And the thumper supplys the drummer
Figure it's time to try using a stepper motor.
I'll need the motor, DC power supply, Driver and a signal generator to drive the driver
The parts are on order
While I'm waiting for parts, figured I'd design a new speed controller
Yes, that's heat shrink used for a coupler
I don't have all the parts yet, so I'm doing a prototype
Those work good for turning a rummagerKareltje wrote:As for the motor: a friend used the motor of a windshieldwiper. Alternating movement already build in.
What are you using for a shaft seal? I plan to make an agitator using a brushless DC gearmotor. Speed control from a power supply for now. Not sure how I seal on the 1/4” shaft.
Here's a couple picts
The tube came from a corny keg
The compression coupling from my junk box
- der wo
There is no need for a shaft seal, if the shaft bushing is always immersed into the wash. It has to be a long bushing of course when usig this method. See the link in my signature.Jeff34 wrote:What are you using for a shaft seal? I plan to make an agitator using a brushless DC gearmotor. Speed control from a power supply for now. Not sure how I seal on the 1/4” shaft.
shadylane wrote:Here's a couple picts
The pressure seal is the shaft bushing being immersed in the wash
The homemade top seal stops the little bet of leakage
