junkyard dawg wrote:Tested how? what methodology? was a GCMS involved or did it just look ok?
Riku, I respect your knowledge of stills and appurtances, but I respectfully disagree. I had a few years of working in a plastic testing lab to determine my stance. Even tho the risk from some of the things talked about in this post may be small, I believe in the interest of general safety that only the best practices should be advocated on this forum. or any other distilling forum. When I see the best distillers in the world using a plastic boiler I might think twice, but until then....
There are proven safe materials to use in a still... This eliminates only one of the many dangers involved in this hobby, but its a start. We're not talking about ways to cobble together some prison toilet hootch, we want to make a good, (relatively) safe product. The best you can say about this plastic bucket and aquarium heater still is that it will generally perform the function of an ethanol seperator. Maybe we can start a new forum or section here to discuss these types of still. maybe jailhousetoiletbooze.com???
------------------------------------junkyard dawg wrote:Riku, I took out the rubber orings in my cheap brass needle valves and replaced it with ptfe tape. took a few tries to get it right, but works fine. hasn't leaked yet. I had done a few runs with the rubber and it crumbled with it came off.
jd, being so against PP plastic, what about that cheap needle valve of yours...
- Are you sure that no led is leeched out of the brass and gets into your
spirits?
- Do you know if the valves are tested?
- Is it a proven safe material to use?
- Or does it just look OK to use it?
- Are you sure it's safe to drink your hooch (or is it jailhousetoiletbooze
you're making)?
/Miraculix
