![Image](http://www.homedepot.com/catalog/productImage/8f184378-50ce-40ab-aacb-a6bc70786734_300.jpg)
Has anyone tried to use these for fermentation containers?
It is getting annoying for me to have to use 2 gallon buckets that I got at the brew store for fermentation. They are just two small and I always have to use them both. So instead of buying a carboy or something else I was thing about using one of those 5 gallon water dispenser bottles. They sell empty ones at home depot for $4 and some change! They are used for water so they would have to be food grade. So I was thing of just sticking a bung that would fit in it and using that. Think it would be ok? I guess it's either that or find some other cheap container. Here's what I'm talking about:
I would not use the plastic water jugs for fermenting. When I first started out 15 years ago I tried them. They worked for a bit but in a short time the alcohol started to break down the plastic. As my pallet got educated I could tell a difference in taste. Just go and get a fermenting bucket at the brew shop and ferment in that. When the S gravity is low enough then rack into a glass carboy with an air lock to finish fermenting and storage until ready to use. Or like many others use, get an old keg.
Really? The plastic came off in your taste, even when it's at that low of an alcohol content? I would rather not have to buy the ones at the beer shops but I guess I can put some on my christmas list
. I guess I'll have to get glass, I don't know about you guys but I just like to be able to see it while it's fermenting. It drives me crazy when I can't see inside those white buckets. Wait what about the plastic carboys they sell? Should I stay away from those too?
Yeah I would have thought that they would been fine if the plastic food grade buckets are. The buckets at my brew store are high density polyethylene (HDPE) they say that on the bottom. So if those bottles are made from that (which I think they are) shouldn't they be ok. new_moonshiner could you do me a favor and look on the bottom of those bottles and see if they have the number 5 recylcing number. If they are then they are make from HDPE. Any reason why you don't ferment in those too?
Yes it did come off in the taste. I was making wine in mine. I noticed it more in the white wines than the red. You do not notice it right away. It takes a wile to start breaking down but it will. If you need something for short term you can use them. It has been a wile since I did it but I think it was after about 20 batches. Plus one more thing. If you put something with a strong flavor in it is sometimes in the plastic. You have a good idea you to put one on your Christmas list. I know I got a few over time for Christmas..
Mine have a number 7 in the recycle emblem I use a 20 gal plastic barrel.. I'll find a pic of it and post it in a sec .. still looking for a pic
here is what I use to do the primary ferment then let it clear in the 5 gal bottles ..this is mine
![Image](http://i153.photobucket.com/albums/s239/johnhoe/894c_1.jpg)
![Image](http://i153.photobucket.com/albums/s239/johnhoe/8495.jpg)
![Image](http://i153.photobucket.com/albums/s239/johnhoe/8496.jpg)
Last edited by new_moonshiner on Tue Dec 04, 2007 4:12 pm, edited 6 times in total.
Here:
http://www.pressedforwine.com/equipment/carboy.shtml
That says not to use any plastic containers for wine because it can give them off taste. But it doesn't say anything about other things. I know that doesn't mean anything for sure but I'm just having trouble understanding why it would come off in taste when it doesn't for the plastic buckets they sell at the brew stores. What do you think about the plastic ones that they sell at the brew store? Those say that they supposedly don't give off any taste. I would rather not use glass but I guess I will if I need to.
Just looked it up and it looks like as long as you get PET plastic they shouldn't give off any flavor/taste or any oxygen. You said that you used them 15 years ago, maybe its possible that they were made of a different material which is why they gave off flavor. I think for only 4 bucks it may be worth a try, but I will think about it some more. New_moonshiner can you check to see whether those containers are HDPE or PET, hopefully it will say on the bottom.
Nothing else that I can find just the number 7 im looking into it more ..using them about a year now ..found this
http://www.plasticsmythbuster.org/resin_code_5.asp" onclick="window.open(this.href);return false;" rel="nofollow
http://www.epa.gov/jtr/jtrnet/plasbott.htm" onclick="window.open(this.href);return false;" rel="nofollow
Last edited by new_moonshiner on Tue Dec 04, 2007 4:40 pm, edited 3 times in total.
Well since I did try them a log time ago maybe the plastic has made some improvements. The buckets you get at the brew shop I only use as a primary fermented. I start out with it and when the specific gravity drops to 1.040 then I transfer it to a glass carboy. It is usually only in the primary for about a week. I have some primary’s I used to make beer and wine and only use them for that purpose because of the flavors left in the plastic.
There is a grocery store nearby that sells those 5 gallon jugs for $3 filled with purified drinkingh water. They then tack on a $7 deposit. To me it has been amazing because I get cheap water for my hobby ... then a decent job rinsing out this fermenter and trade in for a new one. I love my system. The only thing better would be if they were filled with distilled water instead of the purified drinking water. Use em.
I would normally say something at this point.........Sweettuff wrote:There is a grocery store nearby that sells those 5 gallon jugs for $3 filled with purified drinkingh water. They then tack on a $7 deposit. To me it has been amazing because I get cheap water for my hobby ... then a decent job rinsing out this fermenter and trade in for a new one. I love my system. The only thing better would be if they were filled with distilled water instead of the purified drinking water. Use em.
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
2"x38" Bok mini and
Pot still with Leibig on 45 litre boiler
Another option.
I do 80 liter washes in a 105 liter opaque white Rubbermaid storage container
complete with lid.
In Canada these containers are available at Canadian Tire and Walmart.
They come in a variety of shapes and sizes.
They work like a damn and they are inexpensive.
G
complete with lid.
G
Where I live the places that sell those water containers have spring water and distilled water. You could try home depot, I know they have them. Birdwatcher that sounds like another good idea too.Sweettuff wrote:There is a grocery store nearby that sells those 5 gallon jugs for $3 filled with purified drinkingh water. They then tack on a $7 deposit. To me it has been amazing because I get cheap water for my hobby ... then a decent job rinsing out this fermenter and trade in for a new one. I love my system. The only thing better would be if they were filled with distilled water instead of the purified drinking water. Use em.
Bsnapshot wrote:birdwatcher
The Rubbermaid storage container you use are they the square ones? do you have a photo of the kind you use?
They are rectangular or square depending on capacity. They are not round.
G
jake wrote:igloo cooler (120) drilled hole in lid put in a piece of tubing for blowoff.
put cork in hole from bottom of lid when using to keep beer cold.
multitasker!
Hi Jake,
Is that beer cooler 120 liters or bottles? If bottles, what is its capacity. What is it made of and where did you buy it? Are they available at Lowes or Walmart?
G
arkansas wrote:Birdwatcher, I have seen them at Wal-Mart many times, 120 refers to quarts, so should be about 30 gals.
Just thinking out loud here; but assuming this is an insulated metal container
with a hinged top; through that drilled hole in the top you could dangle
an appropriate wattage aquarium heater to heat your wash.
I'll check these puppies out. Thanks.
G
