My Bits
riff42
Location: My desk, somewhere in the east of somewhere....
Post by riff42 »
HookLine wrote:If you can seal the ends properly, then water will work. But you cannot solder the second end with water in the tube, you will not be able to get the temp of the copper/solder anywhere near high enough.
Salt is pretty cheap, and not too difficult to get out, just hook a hose up to one end of the coil, turn the tap on, and wait 30-60 minutes.
It is possible to do it without any filling in the tube, but it does take a certain knack. I have made two without any filling.
ONE
TWO
The smaller inner coil is much harder to wind than the bigger outer coil. For both of them, starting the wind, the first turn and a half, is the hardest part.
Can you make me one? ;)
should fit in a 2 or 2.5" pipe.
I want my last words to be:
"Hey, this is kind of fun!!"
Dutchmancreek
Post by Dutchmancreek »
[quote="Froggy [/quote]How do you get the salt into the tube? I've been thinking about this all afternoon and be stuffed if I can come up with a good way :?[/quote]
I straighten the roll and bend it gently into a big "U". Have someone hold it upright and stand on a ladder (I stood on a retaining wall) and pour salt into both ends, tapping all the while. When it is completely full crimp the ends, straighten the tube and get ready to coil it around whatever mandrel you're going to use. After you make your coil cut off the crimps and attach one end to a hose to melt out the salt.
Never take off your hat, never sign your name
Blind Eye
Post by Blind Eye »
How about soldering 1 end, filling with water,putting a valve with either a flair or compression fitting on the other??
Samogon
Post by Samogon »
HookLine wrote: So whatever you do, don't let him see THIS.
May I ask where that picture is taken? I know most fab shops look the same, but darned if that don't look familiar.
HookLine
Post by HookLine »
I have no idea at all. I just saw it on a distilling site somewhere.
Be safe.
Be discreet.
And have fun.
