Copper scrubbers
Copper scrubbers
Just finshed my first run with a reflux, brown sugar/mollassas wash. I used copper scrubbers as packing, and found them black when I was done, as well the distillate was a bit cloudy. After taking them out I found out that they stick to a magnet, so they're not pure copper. the juice cleared up after putting it through a carbon filter, and doesn't taste too bad, just wondering if it is alright to drink??
yeah i cleaned it out pretty good, and ran a test run of water for a while, I heard something about the wash being too acidic can make this happen??
the cloudyness was more than likley my fault ( getting used to the temps., cooling , nutrients, & not insulating the coloumn). But I don't know where the blackness on the scrubbers came from.
The relationship between scrubbers, strength and flavour is all reletive.
More scrubbers, more column height = higher %abv and less flavour.
Fewer scrubbers, less column height = lower %abv and more flavour.
No scrubbers, no column = less %abv and lots of flavour.
Choose your own combination.
Cheers.
Cheers.
2"x38" Bok mini and
Pot still with Leibig on 45 litre boiler
Your flavor has to do with ratio of water to alcohol the flavor is in the water .Thats why pot still have more flavor.And reflux trying for neural have less.Contact with copper takes I think its sulfates outta the vapor improving taste. Long as packing isn't restricting vapor flow wouldn't mater how many or few scrubbers you use.tracker0945 wrote:The relationship between scrubbers, strength and flavour is all reletive.
Cheers.
