Question about heating boiler
Hey all, ive been playing around with this for a little while and something has occured to me, and i dont know the answer.
this question is about the input heat to the boiler, and i did look on the parent site but didnt run by it.:
when i start my run, i turn my 1500watt hot plate to full power. it usually takes about an hour or so to start boiling. once i get to about 65deg c, i turn on the water and cut the heat back to a little over half. that is where my off-set set-up will run at @ 78-80deg c pretty steady. (heres the question): do i fittle with the input heat to hold it as steady as i can, or do i leave it alone and base my run off the set input heat?(start at 78.5 and cut it off at 90 or so)
i got to thinking about this during my last run when the temp started climbing to 90 after sitting at 80 for only @ an hour, and about 250ml of output.
like i said, ive been "playing" with this for a while, and now im regrouping and trying to learn how to do it correctly. i have gotten alot of help and usefull info from all of you before, and thats what keeps my coming back.
thanks
thanks
is the heating element in a keg the best way to go for a neutral spirit set-up?
im not to electricly inclined to be by-passing thing, i have no idea how you would go about that. i want to do the hot-water element in a quarter-barrel keg i have, but im not sure how to control the heat.
does someone know of a link or thread that might help me? i do have a co-worker who is electric savy, so im not out of it all together.
thanks mackerel...
thanks mackerel...
I'm glad you asked this question, 'cause I have the same doubt.
I've only done 3 runs myself, but I get the sneaking suspicion that I run my pot still too hard, trying to maintain that thin pencil-lead stream of distillate.
I wish I could rent-a-distiller for a day or so, to consult, and have him smack me in the back of the head when needed.
[/quote]
i hear ya their...
i did find this ; http://homedistiller.org/forum/viewtopi ... d59631e599" onclick="window.open(this.href);return false;" rel="nofollow
im going to go to lowes and see what i can find today. hell, ill try to blow anything up at least once..
ill let you know how it turns out.
i hear ya their...
That is my real question..
heres what i do: i get the top of the column up to 78-80deg and hold it their for a while(sometimes an hour, and sometimes a couple hours). then, when the temp starts to go up i lower the input to the boiler to make up for it, and so on, and so on........
i just want to know if thats the right thing to do or if i need to just set it and make the cuts from their.
Ha! You see, we're so lost, we don't even know the correct questions to ask!
I thought about it a moment, and came to the conclusion that I wasn't doing it so badly. My still sort of dictates where it wants to be.
In other words, I start the water running @ 60 degrees, and when the distillate started to dribble, I lower the temperature some, until I get that fast dribble/weak stream. It stays there for some time, then slowly gains temp until I cut it off. At about 90 to 92 degrees, I cut it off, cause the tails have been coming out awhile anyway. Mine's a Pot still... Your still will vary.
That is from my "immense" experience of all of 3 runs.
I gather, from what I have read, that trying to keep the temps @ 78 degrees throughout the run is a waste of time. Like Mike said though, each still is specific. Give them more info, and they'll give you pertinent guidance.
sorry about that, i should have put that info in the first post.
i use an off-set head valved reflux with a 2" x 28" column packed with 6mm raschigs(spelling??). my boiler is two stainless steel trash cans i welded top to top and the heat comes from a 1500watt hot plate i got from brewhaus.
im currently in the process or building a new boiler to have more surface area for the steam to come off of, i think that might be part of my OTHER problem.
it just seem that the temp at the top of the column tends to vary more than is should. i can have is running good for an hour and all of a sudden it wants to climb up to 85deg C so i cut the input temp back a little to bring it back down. but then again, i guess part of that could be the hot plate not being consistant heat.
