Your thoughts on this recipe.
A while ago searching the internet I came across the following recipe from a web site that I have lost the link to. I thought I can post it to get your opinion on this one:
Whiskey
INGREDIENTS:
10 lbs. Whole kernel corn, untreated
5 Gallons Water
1 Cup Yeast, champagne yeast starter
DIRECTIONS:
Put corn in a burlap bag and wet with warm water. Place bag in a warm dark place and keep moist for about ten days. When the sprouts are about a 1/4" long the corn is ready for the next step. Wash the corn in a tub of water, rubbing the sprouts and roots off.. Throw the sprouts and roots away and transfer the corn into your primary fermenter. With a pole or another hard object mash the corn, make sure all kernels are cracked. Next add 5 gallons of boiling water and when the mash cools add yeast. Seal fermenter and vent with a water sealed vent. Fermentation will take 7-10 days. When fermentation is done, pour into still filtering through a pillow case to remove all solids.
As presented, this recipe does not use any sugars and relies solely on the corn malt.
If this can be done, wouldn't barley be a better choice to use instead of corn?
Thanks for your feed back.
Whiskey
INGREDIENTS:
5 Gallons Water
DIRECTIONS:
hoochinoo,
I don't mean no harm but you are reinventing the wheel. This has been done every since the European settles discovered maize growing in the new world.
It's called corn likker.
I bet them ol boys Goose knows has made a bunch of it.
Dooley's daddy and grandpa kept from starving to death during the depression due to it.
Fire is the devil’s only friend - Don McLean
Jump in where you can and hang on - Brisco Darling
Very low , like Chicha.I'm curious what the starting SG would be on this.
It can be kicked up by adding this 10 lbs to another 20 that has been boiled and then cooled to about 160f and let sit for a couple of hours. About 5~8% depending on the strain of corn.
I am hoping that sprouts would come out at all since the corn is feed grade and a hybrid. The guy at the feed store did not have any specific information and finally asked me why I wanted to germinated the seeds. So I had to drop the subject. I will try to germinate and try this recipe then.
If this method can produce desirable results at the end, some good hooch, and not having to use any sugars. I will be pleased.
thanks.
thanks.
Be prepared for big flavor from this. It has about three times the flavor of any sugar based wash. I usually run this stuff twice through two thumping pots and it is still strong. It can handle lots and lots of oak. This is one of my personal favorites.If this method can produce desirable results at the end, some good hooch, and not having to use any sugars. I will be pleased.
I wouldn't use boiling water. Boiling water might kill a lot of the enzymes in the malted corn. You should read about cooking mash. The best temperature for starch conversion is around 66.5°C.
Give a man a fish and he will eat for a day. Teach a man to fish and he will sit in a boat all day and drink beer.
Where is your source of info from? Have you actually tried this?2 liters/ kg to 3 liters/kg this will give you an sg from 1.080 to 1.050.
What yeast did you use? In the recipe, I guess, would EC-1118 be the one they are referring to?
Because this would really be something to achieve that high of SG.
Enzymes convert starches to sugars then yeast use sugar to make alcohol . Corn is low in enzymes has just about enough to convert its self.
others as barley have more than Enough so will convert 3-4 times as much
other gran as well. "home made " malt is not as high in enzymes as
commercial
the grain is is bread for grain
not malt but it does work if you want to spend the time and much cheaper (about .50lb ) and you can make malts you can not buy
( as corn)
commercial
( as corn)
