I know it still not welded but how does this look.
I took out the T and fitted a 90 deg bend and a 45 deg bend
Pot still design,I have changed mine again
Re: Pot still design,I have changed mine again
Looks like a potstill
Before you weld it all together, mock it up where you plan to run it. (It's a pain having to put your collection jars on the floor)
Looks very familiar. And should work a treat.
They're tops those copamate flanges. I use the four inch one and have a four to two reducer, just so i can stick my arm in the keg.
- Location: 50 miles past kikatinalong up that dirt track
I think I have seen a still like that somewhere before And Yes it is a pain in the arse(back) having your collection jars on the floor I was planing on going back to gas so the collection point was lower than the flame but now I 've got the lectrikery hooked up and sussed out I dont want to cut into my stillin time to build a wheel rim burner.
Such is life
Thanks boys
Looks good jug head nealy the same as mine fancy that all you need is to get it welded so pull your finger out and get it dun
50 litre keg pot still
25 litre ultra reflux still
