Pintoshine's Fast Fermenting Molasses Wash
Check this out.
http://www.youtube.com/watch?v=JbKQfzutmf4
http://www.youtube.com/watch?v=Xi6R4_9-etY
I would like to contribute a recipe for a really vigorous fermenter with a very good taste. Best of all no long cook time.
I mix all my stuff in a large 25 gallon pot.
First I add 6.5 gallons rain water (important ingredient, no chlorine).
I then measure up the wall to twice the height to know when to stop adding water.
I add 3 gallons of GFS (Gordon’s Food Service) Black Strap Molasses.
In a separate pot, on the stove, I put one gallon of rain water. To this I add 4 one a day style multi-vitamins that I have crushed thoroughly in mortar. I then add 13 teaspoons of DAP (one tsp per gallon of wash). I then add one cup (from GFS 2 pound bag) of Red Star active dry baking yeast. I bring this to a boil and simmer for 15 minutes.
Add the contents from the small pot to the large container. Add another cup of dry yeast. Top up with water to the mark. Stir everything thoroughly. I use a paint stirrer and a drill and aerate well.
This gets split between two 6.5 gallon carboys. The first time I tried this I had to drill out the holes in the fermentation locks to keep them from coming off the bottles. This stuff generates a bit of heat so I don’t have to supply any in a 68 degree F room. The last time I made this it fermented completely in 36 hours. This is pretty good for bakers yeast.
After this is distilled (I use a pot still with a glass doubler) this is a fine drink. Despite the aggressive taste of the molasses, it comes off really smooth for white rum. The vigorous and fast fermentation along with the rain water keep the off tastes to a minimum.
I usually get 2.3 gallons of 100P. I usually hit my expected yield.
The Rum recipe originated in trying to ferment HFCS 55 which I get for $0.25 per pound. The first time I used the GFS Blackstrap, it nearly stuck. I tried a heating pad and more nutrients. The resulting spirit was bad. I was pretty sure the Blackstrap was lacking some nutrients to get a faster and thus cleaner fermentation. So I tried my HFCS55 recipe and it worked better than expected. The only difference in the HFCS55 and the Blackstrap is that the Blackstrap already has enough acidity. For the HFCS55 I have to add about a teaspoon per 5 gallons of wash. I usually shoot for a PH of about 5.5 with the HFCS. It seems to not stress the yeast as bad. Also, I generally try to get a SP of 1.070 for the the sugar. When I make up a batch of HFCS I make whopper sized batches for vodka. The low yield is worth the extremely fast fermentation without having to by Turbos. I prefer to distill a lot rather than wait for long fermentations.
You will notice I mentioned rain water in this discussion a number of times. I have found that clean rain water has some sort of magical property about it that causes things to ferment frantically. It is slightly carbonated and mildly acidic once it sets in the barrel a day or two. It is very nice if you have a clean source because it requires no dechlorination and has no ground contaminants.
Deathwish uses tap water but doesn't get as strong a fermentation, even after dechlorination. I our area we have chloramine and it is a bear to get rid of. We have tried L-ascorbic acid(vitamin C) without good results and also several fish tank dechlorinaters and potassium metabisulfite. Our tap water here is just bad stuff. If you can dechlorinate the water successfully or use spring water it should be fine as long as it is not store bought spring water with preservatives. I just prefer rain water because I am out in the country and collect it for washing cars and watering the garden and many other uses. It comes off the house pure and clean after the initial rain cleans off the roof.
My spring only runs half the year but it is wonderful water too being high in calcium and magnesium. It is 1200 yards from the house and down the hill. I almost need a deep well pump to get it up here. So I only use it once in a while.
pinto -
Those videos look great - nice recipe. Do you think that the recipe would work if brown sugar was substituted for molasses? I can get light brown sugar for $2 more per 50lb sack than white sugar - but molasses here is more expensive than the GFS stuff you're able to get. I'm sure there is no straight across substitution (perhaps a fraction between molasses and brown sugar)- but if you have any ideas I'd appreciate hearing them.
if you use brown sugar, you have to add magnesium sulfate(USP Epsom Salt) at a rate of 1/8 tsp (small pinch) per gallon. 2 tsp per 13 gallons is what I use. In addition you will need acid. Preferably citric acid which is available in most wine and beer suppliers. I get mine locally at an Indian/Pakistani grocery. The citric acid is used at 2 tsp per 13 gallon also. Be careful of the acid it is really strong and will really acidify the stuff too much if you overdo it.
Wikipedia says that you can use 3/4 cup of firmly packed brown sugar to substitute for 1 cup of molasses.
When you say one a day stle multi-vitamins do you mean like the vitamins that people take? And sorry but what is DAP?pintoshine wrote: In a separate pot, on the stove, I put one gallon of rain water. To this I add 4 one a day style multi-vitamins that I have crushed thoroughly in mortar. I then add 13 teaspoons of DAP (one tsp per gallon of wash). I then add one cup (from GFS 2 pound bag) of Red Star active dry baking yeast. I bring this to a boil and simmer for 15 minutes.
Last edited by MisterSteve124 on Sat Dec 15, 2007 8:06 pm, edited 1 time in total.
- Site Admin
hmm
Last time I did a molasses wash it was 100% molasses. I heated it to 145F or so then let it cool down on it's own. It took a long time to cool down. Then I pitched the yeast and it fermented out in about 24 hours.
Yes, we mean the daily multivitamins that people would take. The multivitamin provides assorted minerals and vitamins (esp. the B-complex) that are either not present in the molasses or not enough in large quantities. A lot more is present in the 2 cups of dead yeast.MisterSteve124 wrote:When you say one a day stle multi-vitamins do you mean like the vitamins that people take? And sorry but what is DAP?
DAP=Diammonium Phosphate. More on it here: http://en.wikipedia.org/wiki/Diammonium_phosphate
DAP is a commercial nitrogen source used in agriculture. Homebrewers use it as a yeast nutrient.
I still call it DAP out of habit. The stuff found in most brew and wine making supplies is like this.
http://www.midwestsupplies.com/products ... rodID=4953" onclick="window.open(this.href);return false;" rel="nofollow
this is exactly what I use but I can get it local to me.
I only heat the nutrients and not the molasses. I boild the nutrients for about 15 to 20 minutes.
pintoshine wrote:In a separate pot, on the stove, I put one gallon of rain water. To this I add 4 one a day style multi-vitamins that I have crushed thoroughly in mortar. I then add 13 teaspoons of DAP (one tsp per gallon of wash). I then add one cup (from GFS 2 pound bag) of Red Star active dry baking yeast. I bring this to a boil and simmer for 15 minutes.
pintoshine wrote:I only heat the nutrients and not the molasses. I boild the nutrients for about 15 to 20 minutes.pintoshine wrote:In a separate pot, on the stove, I put one gallon of rain water. To this I add 4 one a day style multi-vitamins that I have crushed thoroughly in mortar. I then add 13 teaspoons of DAP (one tsp per gallon of wash). I then add one cup (from GFS 2 pound bag) of Red Star active dry baking yeast. I bring this to a boil and simmer for 15 minutes.
You're not gunna consume the mollasses though?RadicalEd1 wrote:Great to hear that the GFS blackstrap can make a fine product; it's a little more per gallon than I'd like to spend but it's certainly fit for human consumption (some animal feeds are not). And it just a few bucks, so why am I complaining?
You're only gunna consume the condensed steam from the finnished ferment.
I stripped a 5 gallon batch of GFS blackstrap wash yesterday (I did cheat from your recipe a bit and used brewers yeast for the fermentation), and slowed it way down halfway through to collect 300mL @60% to see the difference between single and double distilled. I had a more knowledgeable friend come over and give it a try today; he's big on liquor but doesn't know much about the process. It was kinda funny because he was certain it tasted like good heavy dark rum, but the clear appearance told him to expect more bacardi like flavor. Believe you me, the expression on his face was priceless
So now I'm torn between coloring it, spicing it, or leaving it as is :p. I've got a gallon or so a 40% to redistill, so maybe I'll play a bit
Re: Pintoshine's Fast Fermenting Molasses Wash
Im new to all of this, but followed the recipe to a tee..and it is ferminting like crazy..Just been readin other recipes, and wondering...once its done do i let it set to clear? or rack it off to clear? if so, how long just i let it settle? Thanks
This is one recipe that profits in flavor from distilling on a freshly fermented wash. As soon as it quits fermenting, it will usually settle in a matter of hours. Distill the racked of part if you are picky. I usually just dump it in, all but the yeast that is glued to the bottom of the carboy. It gives the rum a full flavor.
Thanks a bunch for your help..This stuff is bubblin' like crazy,lol... One more quick question.. I see you said you have a glass doubler, Being new to this.. I just have a basic pot still, would you suggest double distillin this stuff?
