Now that we have one running bok and several keg based pot stills it's time for a real challenge! Here's what we have so far, but i would appreciate suggestions and advice from those who have built similar things!
Got hold of a few old copper water cylinders, they are not the thickest but all we could find with a limited budget So idea is to do a double walled boiler using the narrower taller cylinder as the inside and the fatter shorter one as the outside. the gap between the two we are thinking of filling with heat transfer fluid/cutting oil as it is not corrosive, has a very high boiling point and is not flammable. the two cylinders would be cut down to sice and welded together leaving the cavity sealed except for a bit of tubing acting as a vent so no pressure builds up and probably a tap near the bottom for emptying the fluid. the inside boiling chamber would have a piece of pipe of at very least 40mm, probably larger with a tap for emptying the wash going through as in the second sketch. The whole thing would then be directly heated on a gas burner. maybe also we'd use the smallest cylinder as either a thumper or as a chamber for the worm. As for the head and the joint, haven't even started thinking about it, saving those headaches for later
What do you think so far? how stable/easy to work with, are fluid filled double boilers? any major issues i'm likely to run into during construction?
