Do I need a thermometer on my pot still?
blanikdog
------MOD EDIT------
This thread is select posts from a rather lively discussion about the need (or lack thereof) for a thermometer in a pot still. If you read through, you'll see that we all have varying opinions about this. In summary, it is not essential, and in order to become a good distiller you should be capable of running a pot still without any instruments at all (alcometer, thermo, etc). However, sometime it can provide extra information about run progression etc that can be useful. It is probably best considered an optional extra.
The one thing almost everyone agrees on is that you shouldn't use a thermometer to make cuts on a pot still - use your senses.
Original discussion here: http://homedistiller.org/forum/viewtopi ... 16&t=12791
New discussion thread started here: http://homedistiller.org/forum/viewtopi ... 68&t=43026
If you put some form of boil breaker, ie, bits of brokem porcelain or copper, even small quartz pebbles you can tell by the sound how the boil is going. I still have a thermometer in my kettle but never use it. I guess it's nice 'eye candy' as someone said to me a long time ago.
blanik
blanik
Cumudgeon and loving it.
HookLine
Re: Thermometer on a pot still?
I find a thermometer very useful in pot stilling. Never used a parrots beak.
But you also need to be able to run the still without any instruments as well.
And make your final cuts with taste and smell, not temperature or % abv.
Be safe.
Be discreet.
And have fun.
Be discreet.
And have fun.
Hack
I've never put a thermometer on my pot still. After your first couple runs you'll see it isn't needed or all that useful.
theholymackerel
A thermometer gives someone new to distillin' somethin' to look at while they are tryin' to figure out what the hell is goin' on, but it doesn't give any useful info. Thermometers, in and of themselves, aren't that bad, what's bad is the hole in yer boiler that you'll kick yerself for every time ya look at it in the future.
Hack
The temperature is relative to the percent alcohol in the vapor and on a pot still this percent is also relative to the starting abv of the wash you are running. Yes it will rise as you go through the run and the percentage of alcohol in the vapor goes down, but it's not going to give you any predictable numbers to make cuts by because it also varys with the starting abv of the wash. Unless you are running the exact same wash every time the temp where you want to make your heads and tails cut will vary. This means its smarter and easier to just learn how to make cuts by taste and smell because that will always be right no matter what recipe you're cooking.CletusDwight wrote:Measuring the temperature at the point where the vapour begins to condense tells you exactly what the vapour composition is. (There's a 'Distillation Temperature and Concentration Relationship' graph on the parent site - theory section I think.)
Until you can tell by taste, the composition is a good guide to where to make your 'cuts'. And when to stop collecting tails and turn off the still.
theholymackerel
What makes ya think a tool designed to measure temp will give a more accurate measure of ABV% than a tool specifically designed to measure abv%?CletusDwight wrote: I use a thermometer in my still head because it warns me when things are coming up to temperature at the start and tells me what the current abv is during the run more accurately than a hydrometer.
I won't argue that a thermometer will tell ya when yer boiler is gettin' up to temp, but I can get the same info by lightly touchin' my lyne arm and it doesn't require a hole in my boiler. Boilin' chips don't require a hole either, they warn about imminent boil, but ALSO smooth out the boil AND inform ya of how hard the boil is.
So what useful info are ya gettin' from yer thermometer that makes the hole in the boiler worth it?
Hawke
As we can see, thermo and alco-meter use can almost become a religion. They both have thier place in the learning curve, but most master distillers can tell ya what's what by sight and smell, before they ever taste it. (At least the few I've met)
HookLine
There is a direct and fixed relationship between vapour temp and abv. Basic physics.As I understood it there is a direct relationship between the abv you're pulling off and the temp?
Given that you know the basic composition of the vapour (ethanol/water), then knowing the vapour temp will tell you its abv, and vice versa, knowing the abv will tell you what temp the vapour is.
You do need a phase diagram to read off the abv from the temp. But you also almost always need a temp correction table when using an alcometer. So one way or another you are using a reference chart of some kind.
One big plus of thermos is that they can be used for over temp alarms (the programmable electronic ones anyway).
As far as running a still goes, I regard both thermos and alcometers are just useful tools, that give equivalent information (abv/temp). They should not be used to make the final cuts. That should be done with smell and taste.
Main thing I use thermo for is an extra warning for the boil up and end of run points, as a general guide as to where I am in the run, and for an over temp alarm.
Be safe.
Be discreet.
And have fun.
Be discreet.
And have fun.
olddog
[quote=
I don't see why anyone should deny themselves the use of a valuable tool just because someone else manages without.[/quote]
You can't argue against that
OD
OD
theholymackerel
OK.CletusDwight wrote: When I come to make notes, it means a lot more to me to write down a temperature/abv reading than just sit sniffing at samples.
So yer usin' yer thermometer to make cuts. Fine. How did ya decide at what temp to make the initial cut that yer thereafter copyin'?
See? The original decision where the cuts lie was still a decision that came from yer nose and tongue.
Anyone that consistantly turns out good spirits from a potstill does so usin' their sense of smell and taste. Science can't can't design a tool to make cuts that can even come close to my God-given sense of smell and taste.
If yer usin' any sort of gauge on a potstill 'cause it gives ya a calm feelin' of controll, that's just fine. But it's not necessary, and lets not try and force the new guys to think they must do it this way. As many many experienced distillers have already stated in this thread: they started with a thermometer on their potstill 'cause they thought it was necessary, only to find out later after competency was gained that it was un-needed and made for one more hole in the system to have to seal up.
blind drunk
Mine rises too. I was trying to say that at 80 degrees I collected a wide tasting range of jars. So if I went just by temperature alone, I would have missed the subtle flavour differences when my pot was at 80 degrees, which it hovered at for a couple of hours. In other words, at 80 degrees, the range in smell and flavour was significant enough to make distinct cuts which I would have missed if I went by thermo alone. Cheers, bd.The thermo's been reading 80 degrees solid but I've collected a bunch of nasty heads and a bunch of 500 ml jars that all taste different,
That's odd. Temp on my pot still rises continually through the run.
I do all my own stunts
HookLine
Temp on mine just climbs slowly but relatively steadily (after it hits boiling). Certainly never sits at one temp for two hours. Maybe you had a lot of heads in that charge.my pot was at 80 degrees, which it hovered at for a couple of hours.
Be safe.
Be discreet.
And have fun.
Be discreet.
And have fun.
blind drunk
It was a 26 liter charge of UJSM low wines. I got about 7 liters of heads so far. I'm just airing out the rest but I'm guessing there will be more heads to add to that early count. I sure wish could get through those heads quicker though. bd.Maybe you had a lot of heads in that charge.
edit - closer to 24 liter charge
Usge
I have therms on all my potstill heads. I started on a little 5L copper alembic and I had a therm installed right at the top of the lynearm before it goes down. That was probably the most accurate therm I've had in terms of it's relationship to the theory section of this site. And it helped me immensely starting out...to see what was going on..and have "some" idea what to expect. It also helped me in learning/understanding the basic theory/relationship and how things were connected. (ie., a certain % wash...would start coming off at given temp, at a certain %). And, the understanding that I could work that from different angles..and start with a percent abv I "wanted" ...to what % abv the still charge should be to get there...although it's much more difficult than it sounds...given you don't know exactly what you'll be keeping for "hearts" to blend. It only gives you an idea of where it will "start" coming off. The rest is an estimate. My other 2 heads on my 5 gal pot from the Colonel...the therms are pretty useless other than just a general idea of when the vapor is starting to heat up/rise. They aren't nearly as accurate.
But, in the end, as someone's sig around here used to say......"I ain't never seen no thermometer with taste buds". And I'll add to that...that I've never seen a hydrometer with taste buds either. I've pulled tails at 77% before. I'd have never known that unless I was tasting/smelling what was coming out of the still. While a hydrometer is a more reliable way to measure abv, that in and of itself is also not going to really know whether what you have in the jar is heads or hearts or tails either. It can give you an "idea"...based on where you are in a run. And it can do that more reliably than "most" therms can. But, you still have to taste and smell what comes out. You have to do that to "learn" as well (smell/taste). And the point here is not just to learn the theory of why all this works...but to learn how to apply it/use it. And that takes time (trial and error, practice, experience). And just as there are people here who's experience has been that their hydrometer bobs just before tails on their particular still or etc...there are people..like myself..who've experenced runs using temp that were just as informative and even accurate in their predictions — that's acknowledging that in general, hydrometer readings and their temp based variances are generally a more stable reading overall because of a smaller possible variance scale.
I have nothing against the use of any or all of these things...and I use everything. But, when it comes down to what goes in my blend jar and what gets recycled...that is based exclusively on me and nothing else. As far as the main site goes....it's there to help people learn. When you start out, and you wouldn't know the difference between heads and tails if you bit you on either one.....it's often the recommendation to find "other" ways to make a cut that is NOT dependent upon having experience in taste/smell (ie., cut from 80% to 70%)...so that you can start to learn..unltimately about what you are dealing with. There isn't anyway to just give someone "experience" to know the difference the day they walk through the door. The ultimate goal here is to use all the resources made available to develop your own experience as safely and effectively as possible. The other side to that to keep in mind is...the history of making spirits is long. And there has been plenty of exceptional whiskey, etc., made in this world WITHOUT the benefit of understanding some of the technical and theoretical nuances that are printed there in the main section for anybody to read. So, keep in mind the goal...and that is to make exceptional product that "you" like, safely....at home.
I'll leave off with this..I made the same observations that some of you have here...that temp is part of theory, and why would it not be something you could use, etc., etc. And it "is" all of those things. But, I also got "stuck" for months...doing runs mechanically, without learning a damn thing other than the results were not consistent or what I wanted. One time..a cut from 80-70% was fine. The next time..it wasn't. But, as far as the therm and the hydrometer was concerned...it was the "same". It's missing the forest for the trees kind of thing (while still understanding that the trees are what makes up the forest and one cannot exist without the other). So, use whatever helps you understand, learn and get down the road...it is useful. But, it's not a replacement for experience in tasting/etc...and never was. You'll gain that by doing it...over and over and over. And experimenting as well.
The main concern is that we all do those things (experiment) safely — which is exactly why it's important to understand how these things work and why you don't put a valve on the output of a potstill.
Dnderhead
I whould think in the head of the of the thumper, but no matter where you put a thermometer in a pot still
its going to be as handy as a pockit in your underwear. learn to make cuts by taste and smell.
Hack
A thermometer on a pot still is only useful in a general way. Simply put, it won't give enough accuracy to be able to rely on it to make cuts. It will tell you the temperature of the vapor in the column, and from this you can infer the alcohol content of the vapor. However where to make the heads and tails cuts from this will vary depending, on the starting abv of the wash in the boiler, and how hard you are running the heat, add a thumper to this and it gets more complicated. If you still feel you need a thermometer and are using a thumper, put it on the column of the thumper. If it was me, I'd leave it out and focus on learning how to make cuts by taste and smell. Making cuts by taste and smell is the most reliable method and works no matter what because it eliminates all the variables of what's going on with the still and the wash. There is good information on how to do this in the stickys in the novice section. One of the best is the first post in the "distilling advice" stickie.
myles
Re: Do I need a thermometer on my pot still?
I like to use a thermometer and a parrot in combination, and there are two very specific uses for the thermometer. My thermometer goes at the high point in the vapour path, and is used for the following because it is convenient to do so.
1. When the vapour temperature hits 84 deg C, I close the lower by-pass valve on the parrot, or put the parrot into the distillate stream. This minimizes the amount of heads going into the parrot. I don't want the very first stinky heads contaminating the parrot.
2. When the vapour temperature reaches 98 deg C, I switch off the power input to the boiler - but leave the condenser running.
Between these points I depend on making cuts by ritual, but the hydrometer gives me a bit of advanced warning that changes are imminent, so I can change the volume of the cuts taken. Pint volumes between the transitions and just an ounce or so for the duration of the transition.
Damifino
As a complete newbie I think this is spot on. I understand why you dont need a thermometer but as a techie and general geek.. I'd like to archive datapoints in the processes so i can see how it all happens then experiment and muck with it later.theholymackerel wrote: ↑Sun Dec 06, 2009 11:55 am A thermometer gives someone new to distillin' somethin' to look at while they are tryin' to figure out what the hell is goin' on....
cayars
For me the proof and tralle hydromer and/or the thermometer allows me to run my still better and more accurately. When you do runs the same way over and over again things should be very, very similar each run. Both the temp and ABV can become very solid data points.
As just one example if I use a ferment at 8% and strip it down to 10% then run these as a spirit run I know on my pot still that my hearts will come out at 80% and go down to 65%.
So what this allows me to do is take off foreshots and dump these. Then collect in large containers until I get near 80%. Right around 80% I switch to small contains (for later evaluations) and at 79% I start collecting hearts in large containers until I get to 65% where I'll again collect in small containers for evaluation (and maybe some tasting/watered down coming off the still). Then I'll switch to large containers again for tails collection.
So using these two tools I can collect in much bigger containers and reserve small containers where the transition happens. This makes running the still easier as well as making my cuts.
Where others might collect a quart/liter at a time or half quart/half liter per bottle I can use much bigger but then around my cut points collect small amounts like 100mL. That makes doing cuts much easier as I have small samples where the changeover takes place. I get finer control over the cuts I choose for my blend.
This works really well for repeat runs that you have down really well, but works on brand new runs as well if you strip/run and puts you in the ballpark as well as your still will generally run things similar (within reason). Might need more tasting/sample during new runs to help. But these tools and KNOWING how your still runs is the key IMHO. Works for me anyway.
StillerBoy
Pretty much the same for me..cayars wrote: ↑Mon Jan 06, 2020 6:41 am This works really well for repeat runs that you have down really well, but works on brand new runs as well if you strip/run and puts you in the ballpark as well as your still will generally run things similar (within reason). Might need more tasting/sample during new runs to help. But these tools and KNOWING how your still runs is the key IMHO. Works for me anyway.
In reflux or reflux hybrid mode, I have four temp (data points) probes working, providing data during the run.. over the years, I've come to understand what the data at variest point are tell me at those points, and how to use them for what I want the end result to be..
Once the data is understood, on a completely new run, those data indicate when the separation/split will come, and is just a matter of collecting in smaller amount around those points, and on to the next.
Mars
– Albert Einstein
– Albert Einstein
