condenser coil cleaning
kazanas
Post by kazanas »
After 10 years of use, I would like to give my coil a perfect clean.I usually clean it with water but I think there is some smell remaining. I tried to pass an electrician spiral steel through, with a brass, but couldn't.
My coil is from ss , one inch internall diameter.
Any ideas??
HookLine
Re: condenser coil cleaning
Post by HookLine »
Dilute phosphoric acid, about 15%, should be enough. Soak overnight.
Can usually buy it from hardware stores.
Use safety glasses and gloves.
Be safe.
Be discreet.
And have fun.
kazanas
Post by kazanas »
ok thanks.
olddog
Post by olddog »
If you are in OZ its marketed under the "RANEX" name, and obtainable from Bunnings
kazanas
Post by kazanas »
A little bit further from OZ, 30 minutes by the phone, Athens Greece.
BTW, how the name OZ, came from????
Nightforce
Post by Nightforce »
If you can find it, try some TSP (tri-sodium phosphate). My local hardware store had some and it works really well for removing oils. Doesn't polish much, but certainly cleans it really well. Then a good rinse, and you've got some nice clean coils.
blanikdog
Post by blanikdog »
olddog wrote:If you are in OZ its marketed under the "RANEX" name, and obtainable from Bunnings
Thanks for that, OD. On my list for the next time we visit Bunnings. My rig must be crying out for a bloody good cleaning.
blanik
Cumudgeon and loving it.
