Mini Spirit Run
Mini Spirit Run
I have 3.5 liters of 50-60% from a stripping run, should I add water or just run it as is ?? I was hoping to get 1 quart
of 80% when finished, this is my first "keeper" run. I'm running in a potstill btw.
- LWTCS
Re: Mini Spirit Run
Better safe than sorry.
Whats your heat source I wonder?
Re: Mini Spirit Run
Dilute to 40%ABV before re-running for a spirit run.
OD
OD
Re: Mini Spirit Run
I'm using an electric stove, I've yet to measure the total ABV as it's in mason jars, but the still was putting out
arond 60% from an 8% wash. Not much volume to work with I guess.
Re: Mini Spirit Run
Don't even consider charging your still with high proof. Especially if you're doing it in your kitchen when others are around.
Have a read of this:
http://distillers.tastylime.net/library ... /index.htm" onclick="window.open(this.href);return false;" rel="nofollow
Why do you care about the output ABV anyway? You'll be dilluting to drink it anyway. Also, you can keep stripping a fair bit lower than 50%, I stop at 20%.
Three sheets to the wind!
My stuff
My stuff
Re: Mini Spirit Run
I will dilute to at least 40%, I open doors and run fans as well.The burner I use is smaller in diameter than my boiler
and electric as well. I will fill the boiler at least half-way and re-read the safety section. It's easy enough to
get lulled into a false sense of security.
I stripped down to 20% on the first run, 30% on the second.
Re: Mini Spirit Run
Ah good stuff, I misunderstood your 60-50% bit.crunchman wrote:I stripped down to 20% on the first run, 30% on the second.
My stuff
My stuff
Re: Mini Spirit Run
crunchman wrote: It's easy enough to get lulled into a false sense of security.
Too true, crunchman. Stay safe
blanik
Cumudgeon and loving it.
Re: Mini Spirit Run
It's a good thing the safety issue came up, cause I was getting complacent....More reading!....Thanks folks.
Re: Mini Spirit Run
Good thing you bought it up too, I just realised that still charge ABV is missing from our 'basic safety' thread....
My stuff
My stuff
Re: Mini Spirit Run
I reckon we all need to be reminded every now and again. Complacently slowly takes over.
blanik
blanik
