continuous still design
We don’t condone the use of Continuous Stripping stills as a method of running 24/7 as this is a commercial setup only .
Home distillers should never leave any still run unattended and Continuous strippers should not be operated for longer periods than a Batch stripping session would typically be run to minimise operator fatigue..
copperstill
Post by copperstill »
I'm looking for help on working on building a continuous still based on Armagnac stills. I know that I forgot to make a pot still drain in the drawing. I am wondering if anyone can answer if some questions on plate numbers and abv output. I also wondering if anyone has any illustrations or pics of Armagnac stills. It is my intent to run direct fire.
ContFirstScetch.tiff
olddog
Re: continuous still design
Post by olddog »
You might find this site usefull, particularly chapter 5 http://journeytoforever.org/biofuel_lib ... meToC.html" onclick="window.open(this.href);return false;" rel="nofollow
OD
copperstill
Did you mean another chapter other than 5? That chapter is about mashing and starch conversion.
"Go down sun, we don't care, we don't like sunshine, we drink moonshine here. Ain't we, Ain't we going to have a time. Ain't we babe, Ain't we going to have a good time tonight." B. Broonzy
olddog
Post by olddog »
Sorry I got a bit dislexic, it's chapter 7
OD
copperstill
olddog wrote:Sorry I got a bit dislexic, it's chapter 7
OD
I'm familiar with this info. I am more interested in hashing out if I can combine elements of Holsteins ability to open and close bubble cap trays to adjust the final output abv with a patent stills ability to blow off the higher alcohols (so one wouldn't need to age as long) and the Armagnac stills ability to run continuously using the wine/mash/what ever I care to distill as coolant.
kiwistiller
Post by kiwistiller »
sounds like a good design challenge, best of luck to you.
Three sheets to the wind!
My stuff
MuleKicker
Post by MuleKicker »
copperstill, your pic aint there?
-Control Freak-
AKA MulekickerHDbrownNose
kiwistiller
If you click on the frame you can download it.
My stuff
olddog
Post by olddog »
To my knowledge there is only Joe (Rednose) and myself that run plated columns, neither are continious stills, they are single batch production stills. Joe's is a 3 plate column and mine is a 5 plate column.
OD
copperstill
So what are you running through them and what are you getting for final product in purity? Also I am trying to figure out how I go about venting off the higher alcohols that build up on the continuous still.
olddog
Post by olddog »
copperstill
olddog wrote:Here is a link to my last run,http://homedistiller.org/forum/viewtopi ... 4#p6843934
OD
Cool!
Why would you not just use the continous still as a stripper?
