How do you make a car rim burner?
Re: How do you make a car rim burner?
You will NOT regret it blanik. I brazed one up a couple years back, when I had some left over angle iron from a different project. The rim directs the heat pretty well. And best off, you could put a 50 gallon boiler on it. Damn near indestructible.
H.
H.
Is there any advantage to building one of these with a burner from a hot water tank? I've got an old gas hot water tank I was going to get rid of and could use the burner from. It's a natural gas tank but I'd have to run propane on it. As long as I use a propane regulator will that be fine?
Orifice size is different on lp and natural gas pressures to operate at are also.Some can be switched easily others cant .Id look at btu rating to see if burner big enough to heat the size boiler your using.If both lp and ng btu ratings are nor listed on tank next time your at store look at ratings on lp model same size . However if ya change orifice size use regulator and hose like off a gas grill ya can make it work.Hack wrote:Is there any advantage to building one of these with a burner from a hot water tank? I've got an old gas hot water tank I was going to get rid of and could use the burner from. It's a natural gas tank but I'd have to run propane on it. As long as I use a propane regulator will that be fine?
Propane has a higher BTU content than NG, so for home use, NEVER swap one for the other, but for one of these burners, it may actually be an advantage. You'll have to adjust the air a bit to get the flame nice and glue, but that should prove easy.
Most home cook stoves / dryers can be used for either by adjustments or using changeover kits.Water heaters around here are usually one ore the other.Barney Fife wrote:Propane has a higher BTU content than NG, so for home use, NEVER swap one for the other, but for one of these burners, it may actually be an advantage. You'll have to adjust the air a bit to get the flame nice and glue, but that should prove easy.
Right; the adjustment is via a needle, and the kit changes a jet size. Propane, with its higher BTU content, burns hotter, thus requires a smaller jet. But for for use here, that won't much matter, as we dial 'em up or down as necassary anyhow, where a home water heaters is simply on or off.
Thanks, everyone. It sounds like it's worth a try, when I get the time.
I've done a burner from a 14 inch car rim..... .
The 50 litre keg fits too neatly
Stops the air flow .... so had to add a couple of pieces of angle iron to lift the keg up.
All I did was cut a section out of the rim to fit a three ring burner in and paint it ( the rim) with heat resistant paint
First run everything stank of rubber .... since then.... it's all good
TAF
TAF
Build it, don't buy it
thanks can i get the gas usage of that burner pleese as i guide
Don't really know
Haven't emptied a full gas bottle (9kg) yet
Since making the rim burner it is more economical as the flame is closed in
So uses less gas to keep it running
Always start with the three burners going full bore
then trim back to just the middle one on low
A part used bottle of gas without the rim burner took ..... 18hours or more of use to empty
So I suspect 25hrs or so of use ...... just a guess though
TAF
TAF
thanks didnt need like a full description that a great help thamkyou
I really like the utility of the "Car Rim Burner" brilliant idea. I am at the point of trying to figure out a natural gas burner assembly to work off of. I wonder if they can't be improved with larger air holes to better scavange fresh air to the burner ring? Both of those set up's shown, if sitting flat look as if they may be challenged for air if the btu's were cranked up on the burner? Hmmm,.......... my wife never seems to use her spare tire. Cheers, O'Mahony
im deferentially going to try playing with this i have some old car rims lying rwd from partners ex and they were going to the tip till i layed clame to them now going to attempt some different ideas see Wat works the best
