boiling chips possible alternative
suburban hillbilly
Post by suburban hillbilly »
Hi
I am very new to all of this. Bought some chickens for the back yard so thought I better get a still and a rocking chair to boot.
So got myself a pot still and am about to start my first runs. I saw some info about boiling chips and wondered if the the same effect could be achieved by simply scoring or scratching the the bottom of my boiling pot giving a rougher surface for bubbles to form.
Am I barking up the wrong tree or could this work, my initial idea was that it would obviously stop the noise of loose items moving around during boiling operation.
blanikdog
Re: boiling chips possible alternative
Post by blanikdog »
Boiling chips don't make a lot of noise, just a pleasant rattle telling you that the temp is OK and that everything is going well.
Cumudgeon and loving it.
suburban hillbilly
Hi
Thanks for that I'll give it a whirl then. Luckily my wife finds it all so amusing at the moment so I am sure a gentle rattling wont rattle her nerves too much.
All the best
Just a few bits of copper or perhaps a small hand full of broken TEMPERED glass.
As blanik mantioned, will also help you with an audible tool to gage your boil.
ScottishBoy
Post by ScottishBoy »
Drop by any hobby store. They have these flattened disks of glass/ceramic in various colours. They make fanatastic boiling chips. But if you dont want to do that, then just cut some copper pipe into about 3 inch lengths and drop them in. Works very well.
ScottishBoy
HD Survival in a Nutshell...
suburban hillbilly
Thanks guys I will definately try out your suggestions.
Dnderhead
Post by Dnderhead »
boiling chips should be irregular, jagged not smooth.something with a bunch of holes is ideal.(traps air)there is a difference between
something to"rattle" and "braking the boil".
ScottishBoy
Dnderhead wrote:boiling chips should be irregular, jagged not smooth.something with a bunch of holes is ideal.(traps air)there is a difference between
These actually have fairly irregular surfaces on the bottom. The bottom often looks like it was melted on a piece of cast iron. I think they do this in case someone want to glue them to something. It makes good nucleation points and is chemically inert.
ScottishBoy
gobbler777
Post by gobbler777 »
would a couple wads of copper mesh work or does? it need to be something alittle heavier
lacedspirits
Post by lacedspirits »
I've got 100lbs of 1/4" boiling stones and over 200lbs of 1/2" boiling stones, all ceramic. If anyone's interested in a few quart jars full, send me a PM. Let me know how much you need and we'll work out a price. Then again, if you want me to send you 300lbs of boiling stones, I could do that too.
ls
Beat it to fit. Paint it to match.
gobbler777
nevermind i found the answer to my question about the copper, i am curious to know if a handful of pennies would be ok to use? and what years the pennys need to be in order to be safe to use them?im going to be running a wash around 6 tonight anybody got a quick answer for me?
Dnderhead
Post by Dnderhead »
no to the pennies there not all copper, scrap pipe would be better.
ozone39
Post by ozone39 »
How about some small 3/8" and 1/4" copper sweat fittings???? those are irregular and can trap air...
blind drunk
Post by blind drunk »
I use those copper crimp rings I had laying around from some job I was supposed to do but never got around to it :roll: bd.
I do all my own stunts
NcHooch
Post by NcHooch »
I made some springy looking things out of some leftover 12 awg copper wire I had layin around.
NChooch
Dnderhead
Post by Dnderhead »
what is all this about any way, most do not need them, Iv run for years with out. most pots/boilers are not that perfect.
unless it is smooth as glass there not necessary.
LearJet
Post by LearJet »
I use a length of stainless steel chain I picked up from home depot.
